Makita XPH01 Drill Brush Replacement
  1. Makita XPH01 Drill Brush Replacement, Battery: step 1, image 1 of 1
    • Hold the drill upright.
    • Place your finger on the white battery-release button.
  2. Makita XPH01 Drill Brush Replacement: step 2, image 1 of 1
    • Press and hold the white release button located on the front of the battery.
  3. Makita XPH01 Drill Brush Replacement: step 3, image 1 of 1
    • Slide the battery forward while pressing down on the white battery-release button.
  4. Makita XPH01 Drill Brush Replacement, Drill Brush: step 4, image 1 of 1
    • Hold the drill upright with the back panel facing you.
  5. Makita XPH01 Drill Brush Replacement: step 5, image 1 of 2 Makita XPH01 Drill Brush Replacement: step 5, image 2 of 2
    • Unscrew two 18mm screws from the back panel with the Phillips PH2 screwdriver.
  6. Makita XPH01 Drill Brush Replacement: step 6, image 1 of 2 Makita XPH01 Drill Brush Replacement: step 6, image 2 of 2
    • Apply slight pressure to the sides of the backplate and pull away from the drill.
  7. Makita XPH01 Drill Brush Replacement: step 7, image 1 of 3 Makita XPH01 Drill Brush Replacement: step 7, image 2 of 3 Makita XPH01 Drill Brush Replacement: step 7, image 3 of 3
    • Hold the drill so the back end is facing toward you.
    • Use the spudger to lift the spring clip out of the back notch.
    • Pull the spring clip forward and rest it in the front notch.
  8. Makita XPH01 Drill Brush Replacement: step 8, image 1 of 2 Makita XPH01 Drill Brush Replacement: step 8, image 2 of 2
    Tool used on this step:
    Buy
    • Use the tweezers to pull the drill brush away from the sleeve.
  9. Makita XPH01 Drill Brush Replacement: step 9, image 1 of 3 Makita XPH01 Drill Brush Replacement: step 9, image 2 of 3 Makita XPH01 Drill Brush Replacement: step 9, image 3 of 3
    • Use the plastic opening tool to release the clip connected to the drill brush.
    • Separate the drill brush away from the clip.
3 other people completed this guide.
Eric Herwatt
984 Reputation
7 Guides authored
Cal Poly, Team 15-4, Livingston Fall 2016 Member of Cal Poly, Team 15-4, Livingston Fall 2016
CPSU-LIVINGSTON-F16S15G4
4 Members
7 Guides authored
One Comment
Mehr Infos gibr’s hier >> https://makita-set.bernaunet.com
joe - Reply
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 24
All Time: 5,906
