Manatee V2S Intelligent Clothes Dryer Filter Replacement
  1. Manatee V2S Intelligent Clothes Dryer Filter Replacement, Filter: step 1, image 1 of 1
    • Turn the machine upside down.
  2. Manatee V2S Intelligent Clothes Dryer Filter Replacement: step 2, image 1 of 1
    • Use a Phillips #0 screwdriver to remove the 3.5 mm screw holding the bottom case to the device.
  3. Manatee V2S Intelligent Clothes Dryer Filter Replacement: step 3, image 1 of 1
    • Cut out about 10 cm of scotch tape.
    • Turn it over and go around your hand as shown in the image, which lets the adhesive side on the outside. (Because it is easy to remove dust)
    • You can also use any other ways to remove the dust, but make sure not to break the filter.
  4. Manatee V2S Intelligent Clothes Dryer Filter Replacement: step 4, image 1 of 1
    • Take out the filter.
    • Tap the dust and particles into the garbage, remove the dust with scotch tape, or replace the filter.
  5. Manatee V2S Intelligent Clothes Dryer Filter Replacement: step 5, image 1 of 2 Manatee V2S Intelligent Clothes Dryer Filter Replacement: step 5, image 2 of 2
    • Check for broken/loose wiring and other connections.
    • Dust may not be the only reason for the poor performance.
    • Close the lid and replace the screw.
[deleted]
121 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 9
All Time: 511
