Manual recalibration
  1. Manual recalibration, Manual recalibration: step 1, image 1 of 1
    • Open the Thrustmaster Control panel application and set the angle to 1080°
    • If you are using PlayStation, manually set rotation angle to 1080°
    • Unplug and re-plug T-GT II to USB port.
    • Wait for auto-calibration to finish
  2. Manual recalibration, Steer the wheel all the way to the left: step 3, image 1 of 1
    • Keep turning the wheel until you reach a physical stop
  3. Manual recalibration, Steer the wheel all the way to the right: step 4, image 1 of 1
  4. Manual recalibration, Center your wheel: step 5, image 1 of 1
    • Perfectly center your wheel.
    • Keep in mind that rotation is set to 1080°.
  5. Manual recalibration, Press the indicated buttons: step 6, image 1 of 1
    • Press SHARE + OPTIONS + MODE buttons at the same time.
    • LED will flash if successful.
    • If you are using a different wheel, then a button combination will be different. You can find button combination list here.
Finish Line
Formica Fusca
2,595 Reputation
15 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 21
All Time: 338
