Maquet Servo-U Expiratory Cassette Replacement
Medical Equipment
Neither iFixit nor this repair guide is endorsed by or affiliated with the medical device manufacturer.
  1. Maquet Servo-U Expiratory Cassette Replacement, Expiratory Cassette: step 1, image 1 of 1
    • Orient the ventilator so the upgrade slots (front) are facing away from you and that you are looking at the back of the device.
    • Switch off the ventilator system using the on/off switch on the patient unit, which is located on on the lower half of the unit behind a white door panel.
    • Disconnect the ventilator system from the mains power and gas supply.
  2. Maquet Servo-U Expiratory Cassette Replacement: step 2, image 1 of 1
    • In the following order:
    • Press the button on the expiratory cassette.
    • Tilt the cassette upwards and remove.
    • The expiratory cassette is a precision instrument and must be handled carefully.
  3. Maquet Servo-U Expiratory Cassette Replacement: step 3, image 1 of 1
    • Hinge the expiratory cassette and press it firmly down into lock position.
    • Make sure that the cassette clicks into position. Check that it cannot be moved upwards and that the button on top of the cassette is completely ejected.
Finish Line
Cassandra Aarrestad
627 Reputation
4 Guides authored
Cal Poly, Team S7-G2, Paton Spring 2020 Member of Cal Poly, Team S7-G2, Paton Spring 2020
CPSU-PATON-S20S7G2
3 Members
5 Guides authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 12
Past 30 Days: 54
All Time: 3,113
