Marshal Woburn Top Control Panel Replacement
  1. Marshal Woburn Top Control Panel Replacement, Back Panel: step 1, image 1 of 2 Marshal Woburn Top Control Panel Replacement, Back Panel: step 1, image 2 of 2
    • Before starting, unplug the speaker from any power source. After unplugging the device, wait around 10 minutes before starting to let the capacitor fully discharge.
    • On a flat surface, orient the device so that the front grille is facing downward.
    • Using a Phillips #1 screwdriver, remove the ten outer 28.6 mm screws marked in red.
    • Remove the eight inner 28.6 mm screws with the Phillips #1 screwdriver.
  2. Marshal Woburn Top Control Panel Replacement: step 2, image 1 of 2 Marshal Woburn Top Control Panel Replacement: step 2, image 2 of 2
    • Lift the back input board slightly above the back panel.
    • Rotate the input board so that you can slide it into the hole in the back panel that it came from.
    • Fully slide the input board through the back panel and set it down gently inside the speaker.
  3. Marshal Woburn Top Control Panel Replacement: step 3, image 1 of 1
    • Grab the panel by the large hole and lift one side until you can fit your hand under.
    • Use your hand to fully remove the back panel from the rest of the frame.
  4. Marshal Woburn Top Control Panel Replacement, I/O Board: step 4, image 1 of 1
    • Disconnect the 5 wires circled in red from the back input board.
    • Grip and pull the connectors, not the wires.
    • There may be a little resistance when pulling on the connectors, but it should not require excessive force.
  5. Marshal Woburn Top Control Panel Replacement: step 5, image 1 of 2 Marshal Woburn Top Control Panel Replacement: step 5, image 2 of 2
    • Remove the two 12.7 mm screws marked in red from the front of the back input panel with a Phillips #1 screwdriver.
    • Remove the power input from the back side of the panel.
  6. Marshal Woburn Top Control Panel Replacement: step 6, image 1 of 1
    • Completely remove the I/O board and the attached plate.
  7. Marshal Woburn Top Control Panel Replacement, Top Control Panel: step 7, image 1 of 1
    • Using a Philips #1 screwdriver, remove the eight 9.5 mm screws that are marked in red from the perimeter of the metal frame for the top control panel.
  8. Marshal Woburn Top Control Panel Replacement: step 8, image 1 of 1
    • From the outside of the speaker, push down on the top control panel until you can feel the adhesive holding it to the frame start to loosen.
    • On the inside, make your way around the border of the top control panel and remove the adhesive until you can fully remove the panel from the frame.
NateP
284 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 21
Past 30 Days: 52
All Time: 698
