Marshall Monitor Headset Audio Cable Repair
  1. Marshall Monitor Headset Audio Cable Repair, Faulty audio cable between Ear Cups: step 1, image 1 of 3 Marshall Monitor Headset Audio Cable Repair, Faulty audio cable between Ear Cups: step 1, image 2 of 3 Marshall Monitor Headset Audio Cable Repair, Faulty audio cable between Ear Cups: step 1, image 3 of 3
    • Examine the point at which the cable enters the housing to identify the location of the damaged part of the cable.
  2. Marshall Monitor Headset Audio Cable Repair: step 2, image 1 of 3 Marshall Monitor Headset Audio Cable Repair: step 2, image 2 of 3 Marshall Monitor Headset Audio Cable Repair: step 2, image 3 of 3
    • Remove the foam cushion and remove the 4 screws with a Torx screwdriver.
    • Be careful to carefully remove the upper part of the headset.
  3. Marshall Monitor Headset Audio Cable Repair: step 3, image 1 of 3 Marshall Monitor Headset Audio Cable Repair: step 3, image 2 of 3 Marshall Monitor Headset Audio Cable Repair: step 3, image 3 of 3
    • Unsolder the faulty cable connections.
    • Two of the wires are soldered to the transducer (one for ground and one for signal). The third is connected to the input of the 3.5 mm audio jack.
    • Remove the inner foam and undo the cable knot to take it out of the headset.
  4. Marshall Monitor Headset Audio Cable Repair: step 4, image 1 of 3 Marshall Monitor Headset Audio Cable Repair: step 4, image 2 of 3 Marshall Monitor Headset Audio Cable Repair: step 4, image 3 of 3
    • Cut the cable upstream of the damaged area and remove 10mm of insulation.
    • Prepare the wires for soldering. For this, the enamel that isolates the wires from each other must be removed using medium to fine grain sandpaper (120 - 180gr).
    • Next, tin the 3 wires.
  5. Marshall Monitor Headset Audio Cable Repair: step 5, image 1 of 3 Marshall Monitor Headset Audio Cable Repair: step 5, image 2 of 3 Marshall Monitor Headset Audio Cable Repair: step 5, image 3 of 3
    • Solder the 3 replacement wires and mark the corresponding color.
    • Isolate the 3 solder points by placing the heat shrink tubing on each solder joint.
    • Cover the three wires with another piece of heat shrink tubing.
  6. Marshall Monitor Headset Audio Cable Repair: step 6, image 1 of 1
    • There is a good chance that the diameter of the replacement cable will be greater than the original. In that case it will be necessary to remove the original gold cable grommet (it is decorative anyway).
  7. Marshall Monitor Headset Audio Cable Repair: step 7, image 1 of 3 Marshall Monitor Headset Audio Cable Repair: step 7, image 2 of 3 Marshall Monitor Headset Audio Cable Repair: step 7, image 3 of 3
    • Reinsert the cable into the headset
    • Solder the wires to their original locations
    • Place a dot of hot glue where the new cable passes through to hold it in place and avoid strain on the connections.
  8. Marshall Monitor Headset Audio Cable Repair: step 8, image 1 of 3 Marshall Monitor Headset Audio Cable Repair: step 8, image 2 of 3 Marshall Monitor Headset Audio Cable Repair: step 8, image 3 of 3
    • Replace the foam inside the headset then gently reposition the upper part.
    • Tighten the 4 Torx screws and replace the foam of the outer pads.
Crank up the volume!
4 other people completed this guide.
Special thanks to these translators:
fr en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
Albertine Carabine
274 Reputation
1 Guide authored
One Comment
protip, you should not fold the headphones like the first picture. its was causes the damage to begin with.
Thomas DH - Reply
Past 24 Hours: 8
Past 7 Days: 49
Past 30 Days: 197
All Time: 10,155
