Marshall Woburn Back Panel Replacement
  1. Marshall Woburn Back Panel Replacement, Back Panel: step 1, image 1 of 2 Marshall Woburn Back Panel Replacement, Back Panel: step 1, image 2 of 2
    • Before starting, unplug the speaker from any power source. After unplugging the device, wait around 10 minutes before starting to let the capacitor fully discharge.
    • On a flat surface, orient the device so that the front grille is facing downward.
    • Using a Phillips #1 screwdriver, remove the ten outer 28.6 mm screws marked in red.
    • Remove the eight inner 28.6 mm screws with the Phillips #1 screwdriver.
  2. Marshall Woburn Back Panel Replacement: step 2, image 1 of 2 Marshall Woburn Back Panel Replacement: step 2, image 2 of 2
    • Lift the back input board slightly above the back panel.
    • Rotate the input board so that you can slide it into the hole in the back panel that it came from.
    • Fully slide the input board through the back panel and set it down gently inside the speaker.
  3. Marshall Woburn Back Panel Replacement: step 3, image 1 of 1
    • Grab the panel by the large hole and lift one side until you can fit your hand under.
    • Use your hand to fully remove the back panel from the rest of the frame.
NateP
284 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 10
Past 30 Days: 46
All Time: 753
