Master and Dynamic MW50 Battery Replacement
  1. Master and Dynamic MW50 Battery Replacement, Master and Dynamic MW50 Disassembly: step 1, image 1 of 3 Master and Dynamic MW50 Battery Replacement, Master and Dynamic MW50 Disassembly: step 1, image 2 of 3 Master and Dynamic MW50 Battery Replacement, Master and Dynamic MW50 Disassembly: step 1, image 3 of 3
    • Pull the cushion off of the desired side by gripping the top of the headphones and pulling the cushion off.
  2. Master and Dynamic MW50 Battery Replacement: step 2, image 1 of 1
    • Remove the four 5mm screws from the earpiece with a Y1 Triwing screwdriver.
  3. Master and Dynamic MW50 Battery Replacement: step 3, image 1 of 1
    • Use the Jimmy to lift up the black cover to get inside the device.
  4. Master and Dynamic MW50 Battery Replacement, Battery: step 4, image 1 of 2 Master and Dynamic MW50 Battery Replacement, Battery: step 4, image 2 of 2
    • Remove the tape attaching the thicker white wire to the battery. You may consider keeping the tape to reattach the wire later.
  5. Master and Dynamic MW50 Battery Replacement: step 5, image 1 of 1
    • Desolder the two wires circled here.
  6. Master and Dynamic MW50 Battery Replacement: step 6, image 1 of 2 Master and Dynamic MW50 Battery Replacement: step 6, image 2 of 2
    • Use an iFixit opening tool or something similar to pry out the battery.
    • There are two small tabs circled here that are holding the battery in. Push these down while prying to make the battery come out easier.
Tyler Guffey
208 Reputation
2 Guides authored
Cal Poly, Team S1-G4, White Winter 2019 Member of Cal Poly, Team S1-G4, White Winter 2019
CPSU-WHITE-W19S1G4
4 Members
12 Guides authored
2 Guide Comments
Hi, do you know where it’s possible to buy replacement batteries??
Mike - Reply
Did you ever find out what spec of battery and where to buy? Really want to run my MW50s wirelessly again.
TP 75 -
Past 24 Hours: 2
Past 7 Days: 11
Past 30 Days: 40
All Time: 2,395
