Master and Dynamic MW50 Charging Port Replacement
  1. Master and Dynamic MW50 Charging Port Replacement, Master and Dynamic MW50 Disassembly: step 1, image 1 of 3 Master and Dynamic MW50 Charging Port Replacement, Master and Dynamic MW50 Disassembly: step 1, image 2 of 3 Master and Dynamic MW50 Charging Port Replacement, Master and Dynamic MW50 Disassembly: step 1, image 3 of 3
    • Pull the cushion off of the desired side by gripping the top of the headphones and pulling the cushion off.
  2. Master and Dynamic MW50 Charging Port Replacement: step 2, image 1 of 1
    • Remove the four 5mm screws from the earpiece with a Y1 Triwing screwdriver.
  3. Master and Dynamic MW50 Charging Port Replacement: step 3, image 1 of 1
    • Use the Jimmy to lift up the black cover to get inside the device.
  4. Master and Dynamic MW50 Charging Port Replacement, Charging Port: step 4, image 1 of 2 Master and Dynamic MW50 Charging Port Replacement, Charging Port: step 4, image 2 of 2
    • Remove the two 2mm screws pictured with a JIS #00 screwdriver.
    • Gently pull the silver cover off of the ear piece.
  5. Master and Dynamic MW50 Charging Port Replacement: step 5, image 1 of 1
    • Remove the two 2mm screws shown with a JIS #00 screwdriver.
  6. Master and Dynamic MW50 Charging Port Replacement: step 6, image 1 of 1
    • Lift up the mother board with the attached charging port to see the soldering points. You must desolder these points in order to detach (and re-attach) the charging port.
Tyler Guffey
208 Reputation
2 Guides authored
Cal Poly, Team S1-G4, White Winter 2019 Member of Cal Poly, Team S1-G4, White Winter 2019
CPSU-WHITE-W19S1G4
4 Members
12 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 9
All Time: 329
