Matsunichi MarquisPad MP977 Battery Replacement
  1. Matsunichi MarquisPad MP977 Battery Replacement, Battery: step 1, image 1 of 1
    • Remove the two screws using a Phillips #00 screwdriver.
  2. Matsunichi MarquisPad MP977 Battery Replacement: step 2, image 1 of 3 Matsunichi MarquisPad MP977 Battery Replacement: step 2, image 2 of 3 Matsunichi MarquisPad MP977 Battery Replacement: step 2, image 3 of 3
    • Place the device face down on a flat surface.
    • Insert one of the wide-tipped, plastic opening tools into the top of the left speaker slot.
    • Be sure to avoid puncturing the covering of the speaker.
    • Pry the back plate open and slide the tool in a clockwise direction, moving it along the opening between the device and its back plate until you reach the power button.
  3. Matsunichi MarquisPad MP977 Battery Replacement: step 3, image 1 of 2 Matsunichi MarquisPad MP977 Battery Replacement: step 3, image 2 of 2
    • Insert the opening tool into the right speaker slot.
    • Pry open the back plate, and slide the tool counterclockwise along the device until you reach the charging port.
  4. Matsunichi MarquisPad MP977 Battery Replacement: step 4, image 1 of 1
    • Remove the back plate and place it to the side.
  5. Matsunichi MarquisPad MP977 Battery Replacement: step 5, image 1 of 2 Matsunichi MarquisPad MP977 Battery Replacement: step 5, image 2 of 2
    • Detach the battery from the motherboard.
3 other people completed this guide.
Evan Campbell
88 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 24
All Time: 1,601
