Matsunichi MarquisPad MP977 Front Facing Camera Replacement
  1. Matsunichi MarquisPad MP977 Front Facing Camera Replacement, Front Facing Camera: step 1, image 1 of 1
    • Using the PH #00 Phillips head screwdriver, remove the two screws.
  2. Matsunichi MarquisPad MP977 Front Facing Camera Replacement: step 2, image 1 of 3 Matsunichi MarquisPad MP977 Front Facing Camera Replacement: step 2, image 2 of 3 Matsunichi MarquisPad MP977 Front Facing Camera Replacement: step 2, image 3 of 3
    • Place the device face down on a flat surface.
    • Insert the wide-tipped plastic opening tool into the top of the left speaker slot.
    • Potential for device damage: Do not puncture the speaker cover.
    • Pry the back plate open and slide the tool in a clockwise direction, moving it along the opening between the device and the back plate until you reach the power button.
  3. Matsunichi MarquisPad MP977 Front Facing Camera Replacement: step 3, image 1 of 2 Matsunichi MarquisPad MP977 Front Facing Camera Replacement: step 3, image 2 of 2
    • Insert the opening tool into the slot to the right of the speaker on the top edge of the device.
    • Then, pry open the back plate of the device, and slide the tool counter clockwise along the device until you reach the charging port.
  4. Matsunichi MarquisPad MP977 Front Facing Camera Replacement: step 4, image 1 of 1
    • Remove the back plate and set it aside.
  5. Matsunichi MarquisPad MP977 Front Facing Camera Replacement: step 5, image 1 of 1
    • With the same PH #00 Phillips head screwdriver, remove the seven screws holding in the motherboard.
    • Place the screws somewhere safe where they won't fall.
  6. Matsunichi MarquisPad MP977 Front Facing Camera Replacement: step 6, image 1 of 2 Matsunichi MarquisPad MP977 Front Facing Camera Replacement: step 6, image 2 of 2
    • Gently pull the camera optic fiber out of its slot to release the flap. This will allow the flap to open easily.
    • Be sure not to damage the camera port.
  7. Matsunichi MarquisPad MP977 Front Facing Camera Replacement: step 7, image 1 of 2 Matsunichi MarquisPad MP977 Front Facing Camera Replacement: step 7, image 2 of 2
    • Finally, insert the new camera into the pinhole camera slot.
Kathryn Sherlock
127 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 18
All Time: 296
