Matsunichi MarquisPad MP977 Plastic Front Panel Replacement
  1. Matsunichi MarquisPad MP977 Plastic Front Panel Replacement, Plastic Front Panel: step 1, image 1 of 1
    • Remove the two screws using a PH #00 Phillips head screw driver.
  2. Matsunichi MarquisPad MP977 Plastic Front Panel Replacement: step 2, image 1 of 3 Matsunichi MarquisPad MP977 Plastic Front Panel Replacement: step 2, image 2 of 3 Matsunichi MarquisPad MP977 Plastic Front Panel Replacement: step 2, image 3 of 3
    • Place the device face down on a flat surface.
    • Insert one of the wide tipped, plastic opening tools into the top of the left speaker slot.
    • Be sure not to puncture the covering of the speaker.
    • Pry the back plate open and slide the tool in a clockwise direction, moving it along the opening between the device and its back plate until you reach the power button.
  3. Matsunichi MarquisPad MP977 Plastic Front Panel Replacement: step 3, image 1 of 2 Matsunichi MarquisPad MP977 Plastic Front Panel Replacement: step 3, image 2 of 2
    • Insert opening tool into the right speaker slot.
    • Pry open the back plate, and slide the tool counter clockwise along the device until you reach the charging port.
  4. Matsunichi MarquisPad MP977 Plastic Front Panel Replacement: step 4, image 1 of 1
    • Remove the back plate and place it to the side.
  5. Matsunichi MarquisPad MP977 Plastic Front Panel Replacement: step 5, image 1 of 1
    • Remove the screws holding the metal frame plate in place.
    • Remove the metal frame plate from the plastic housing.
  6. Matsunichi MarquisPad MP977 Plastic Front Panel Replacement: step 6, image 1 of 2 Matsunichi MarquisPad MP977 Plastic Front Panel Replacement: step 6, image 2 of 2
    • Place the metal frame plate and components into the new plastic front panel.
Rachel Servis
89 Reputation
1 Guide authored
One Comment
where can you order the front plastic panel from? and how much?
daf01ca - Reply
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 6
All Time: 380
