Mavic 2 Camera/Gimbal Unit Replacement
  1. Mavic 2 Camera/Gimbal Unit Replacement, Camera/Gimbal Unit: step 1, image 1 of 1
    • Remove the two 2x5 mm screws from the plastic piece near the camera on bottom side using the Allen key.
  2. Mavic 2 Camera/Gimbal Unit Replacement: step 2, image 1 of 1
    • Remove plastic part from previous step.
  3. Mavic 2 Camera/Gimbal Unit Replacement: step 3, image 1 of 1
    • Remove ribbon cable connecting to camera by pulling at camera connection point.
  4. Mavic 2 Camera/Gimbal Unit Replacement: step 4, image 1 of 1
    • Unscrew 1.5 x 4.5 mm gimbal mount screw using Allen key.
  5. Mavic 2 Camera/Gimbal Unit Replacement: step 5, image 1 of 1
    • Use Allen key to remove screws holding nose plate, in the front left and right corners in front of the camera.
  6. Mavic 2 Camera/Gimbal Unit Replacement: step 6, image 1 of 1
    • Pull camera and gimbal from drone.
  7. Mavic 2 Camera/Gimbal Unit Replacement: step 7, image 1 of 1
    • Remove four rubber parts from camera mount.
  8. Mavic 2 Camera/Gimbal Unit Replacement: step 8, image 1 of 1
    • Remove camera from frame by pulling apart.
ColynOB
172 Reputation
1 Guide authored
IUPUI, Team 2-3, Harley Fall 2023 Member of IUPUI, Team 2-3, Harley Fall 2023
IUPUI-HARLEY-F23S2G3
3 Members
4 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 36
All Time: 587
