Maylong M-270 Battery Replacement
  1. Maylong M-270 Battery Replacement, Motherboard: step 1, image 1 of 2 Maylong M-270 Battery Replacement, Motherboard: step 1, image 2 of 2
    • Use the plastic opening tool to separate the back cover plate from the front.
    • Insert the plastic opening tool in between the back plate cover and the top cover, then slide along edges to pry open.
  2. Maylong M-270 Battery Replacement: step 2, image 1 of 2 Maylong M-270 Battery Replacement: step 2, image 2 of 2
    • Locate the two ribbons attached to the device's motherboard.
    • Flip the small black plastic catches down by using the small end of the spudger.
    • Remove the ribbons by gently pulling them away from the motherboard.
  3. Maylong M-270 Battery Replacement: step 3, image 1 of 2 Maylong M-270 Battery Replacement: step 3, image 2 of 2
    • Remove the two screws from the motherboard.
    • Remove the four screws and metal holds from the edge of the device.
  4. Maylong M-270 Battery Replacement: step 4, image 1 of 1
    • Remove the motherboard by gently pulling it away from the bottom of the device.
  5. Maylong M-270 Battery Replacement, Battery: step 5, image 1 of 2 Maylong M-270 Battery Replacement, Battery: step 5, image 2 of 2
  6. Maylong M-270 Battery Replacement: step 6, image 1 of 3 Maylong M-270 Battery Replacement: step 6, image 2 of 3 Maylong M-270 Battery Replacement: step 6, image 3 of 3
    • Remove the battery by using the spudger to gently pry the battery away from metal case around the front screen.
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 6
All Time: 724
