Maylong MN-1000P Battery Replacement
  1. Maylong MN-1000P Battery Replacement, Bottom Cover: step 1, image 1 of 1
    • Place the netbook top down, with the opening of the netbook facing you.
  2. Maylong MN-1000P Battery Replacement: step 2, image 1 of 1
    • Remove the six 6mm Phillips #00 screws from the netbook.
  3. Maylong MN-1000P Battery Replacement: step 3, image 1 of 3 Maylong MN-1000P Battery Replacement: step 3, image 2 of 3 Maylong MN-1000P Battery Replacement: step 3, image 3 of 3
    • Remove the sticker in the middle of the netbook.
    • Remove the middle 6mm Phillips #00 screw.
  4. Maylong MN-1000P Battery Replacement: step 4, image 1 of 1
    • Using two plastic opening tools, pry off the bottom of the netbook by going around the edges.
  5. Maylong MN-1000P Battery Replacement: step 5, image 1 of 1
    • Remove the bottom of the netbook by lifting the corners.
  6. Maylong MN-1000P Battery Replacement, Battery: step 6, image 1 of 2 Maylong MN-1000P Battery Replacement, Battery: step 6, image 2 of 2
    • Pinch the red and black wires connected to the section closest to the small white connector, and pull to remove them from the motherboard.
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 21
All Time: 300
