Maylong MN-1000P Bottom Cover Replacement
  1. Maylong MN-1000P Bottom Cover Replacement, Bottom Cover: step 1, image 1 of 1
    • Place the netbook top down, with the opening of the netbook facing you.
  2. Maylong MN-1000P Bottom Cover Replacement: step 2, image 1 of 1
    • Remove the six 6mm Phillips #00 screws from the netbook.
  3. Maylong MN-1000P Bottom Cover Replacement: step 3, image 1 of 3 Maylong MN-1000P Bottom Cover Replacement: step 3, image 2 of 3 Maylong MN-1000P Bottom Cover Replacement: step 3, image 3 of 3
    • Remove the sticker in the middle of the netbook.
    • Remove the middle 6mm Phillips #00 screw.
  4. Maylong MN-1000P Bottom Cover Replacement: step 4, image 1 of 1
    • Using two plastic opening tools, pry off the bottom of the netbook by going around the edges.
  5. Maylong MN-1000P Bottom Cover Replacement: step 5, image 1 of 1
    • Remove the bottom of the netbook by lifting the corners.
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Kristen Gismondi
103,871 Reputation
266 Guides authored
iFixit Member of iFixit
Staff
124 Members
24,282 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 7
All Time: 109
