Maze Speed SSB-508 Screen Replacement
  1. Maze Speed SSB-508 Screen Replacement, Motherboard: step 1, image 1 of 3 Maze Speed SSB-508 Screen Replacement, Motherboard: step 1, image 2 of 3 Maze Speed SSB-508 Screen Replacement, Motherboard: step 1, image 3 of 3
    • Remove the back cover by inserting the plastic opening tool at the bottom left corner of the device.
  2. Maze Speed SSB-508 Screen Replacement: step 2, image 1 of 2 Maze Speed SSB-508 Screen Replacement: step 2, image 2 of 2
    • Remove fifteen 2mm Phillips #00 screws.
  3. Maze Speed SSB-508 Screen Replacement: step 3, image 1 of 3 Maze Speed SSB-508 Screen Replacement: step 3, image 2 of 3 Maze Speed SSB-508 Screen Replacement: step 3, image 3 of 3
    • Lift the plastic opening tool up at the bottom left corner to create the gap.
    • Repeat this through all corners to remove the internal casing.
  4. Maze Speed SSB-508 Screen Replacement: step 4, image 1 of 3 Maze Speed SSB-508 Screen Replacement: step 4, image 2 of 3 Maze Speed SSB-508 Screen Replacement: step 4, image 3 of 3
    • Unscrew the 2mm screw at the bottom right of the motherboard.
    • Remove the internal antenna casing from the motherboard.
  5. Maze Speed SSB-508 Screen Replacement: step 5, image 1 of 2 Maze Speed SSB-508 Screen Replacement: step 5, image 2 of 2
    • Unplug the speaker at the top of the motherboard.
  6. Maze Speed SSB-508 Screen Replacement: step 6, image 1 of 2 Maze Speed SSB-508 Screen Replacement: step 6, image 2 of 2
    • Desolder the gold ribbon that is connected to the motherboard at the bottom left corner.
  7. Maze Speed SSB-508 Screen Replacement: step 7, image 1 of 3 Maze Speed SSB-508 Screen Replacement: step 7, image 2 of 3 Maze Speed SSB-508 Screen Replacement: step 7, image 3 of 3
    Tool used on this step:
    Buy
    • Use tweezers to remove cable from the ZIF connectors located at the bottom left of the motherboard.
    • Use the tweezers to remove the second cable from ZIF connector located to the right of the speaker that you unplugged in step five.
    • ZIF connector stands for Zero Insertion Force. Flip the small locking tap before removing the cable.
  8. Maze Speed SSB-508 Screen Replacement: step 8, image 1 of 2 Maze Speed SSB-508 Screen Replacement: step 8, image 2 of 2
    • At this point, the motherboard should be able to be lifted up from the bottom.
    • Use the tweezers to dislodge the speaker.
    • After the speaker is dislodged, flip the motherboard up so that you can see the cable.
    • Using a soldering tool, desolder the cable from the back of the motherboard.
  9. Maze Speed SSB-508 Screen Replacement: step 9, image 1 of 1
    • Remove the motherboard from the back.
  10. Maze Speed SSB-508 Screen Replacement, Screen: step 10, image 1 of 2 Maze Speed SSB-508 Screen Replacement, Screen: step 10, image 2 of 2
    • Apply the heated iOpener to all sides of the screen (left, right, top, and bottom) for 90 seconds (or more if necessary) to soften the adhesive.
  11. Maze Speed SSB-508 Screen Replacement: step 11, image 1 of 3 Maze Speed SSB-508 Screen Replacement: step 11, image 2 of 3 Maze Speed SSB-508 Screen Replacement: step 11, image 3 of 3
    • Use a Jimmy's flexible steel blade to separate the screen from the frame. Insert the blade between the frame and screen then carefully lift using the blade.
    • Gently lift the glass screen and remove from the frame.
  12. Maze Speed SSB-508 Screen Replacement: step 12, image 1 of 3 Maze Speed SSB-508 Screen Replacement: step 12, image 2 of 3 Maze Speed SSB-508 Screen Replacement: step 12, image 3 of 3
    • There will be a thin flat cable at the top of the screen in which you need to carefully peel back.
  13. Maze Speed SSB-508 Screen Replacement: step 13, image 1 of 1
    • Move the connecting wire through the hole at the top frame.
    • Then, remove the glass screen and replace with the new one.
To reassemble your device, follow these instructions carefully in reverse order.
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 5
Past 30 Days: 27
All Time: 1,186
