Meaco Arete One Display Replacement
Video Overview
  1. Meaco Arete One Display Replacement, Remove external screws: step 1, image 1 of 3 Meaco Arete One Display Replacement, Remove external screws: step 1, image 2 of 3 Meaco Arete One Display Replacement, Remove external screws: step 1, image 3 of 3
    • 4x in the vent
    • 4x after removing the water tank (2 at the top and 2 at the bottom (bottom screws not pictured)
  2. Meaco Arete One Display Replacement, pop off white cladding above water tank zone: step 2, image 1 of 1
    • It's difficult to remove but you just have to pull it. This video is handy to see the full dismantle process: https://youtu.be/Oc8chhGgatQ
  3. Meaco Arete One Display Replacement, Unscrew all visible screws: step 3, image 1 of 1
    • Approx 6-8 screws to remove. Objective is to be able to partially pull off white cover on the other side and lift off display cover from top.
    • Just enough to detach it from the display cover on the top
  4. Meaco Arete One Display Replacement, Pop off display cover: step 5, image 1 of 1
    • Depending on which size of unit you have, you may have a plastic clip or a screw here. The clip is difficult to unclip, but a flathead screwdriver can be used to push it in, hard, with one hand while lifting the display cover up with the other
  5. Meaco Arete One Display Replacement, Detach display circuit board: step 6, image 1 of 1
    • Detach the two connectors by squeezing the clamps and pulling them off.
    • The whole top of the unit should now be completely detached
    • Unscrew the two Phillips screws holding the circuit board to the cover
    • Carefully unclip the circuit board
  6. Meaco Arete One Display Replacement, Desolder the 2 digit 7 segment display: step 7, image 1 of 3 Meaco Arete One Display Replacement, Desolder the 2 digit 7 segment display: step 7, image 2 of 3 Meaco Arete One Display Replacement, Desolder the 2 digit 7 segment display: step 7, image 3 of 3
    • The highlighted 10 pins hold the display on
    • Once you've desoldered the pins, use a pair of pliers to grip the 2 digit display and pull it off the circuit board
    • If you connect the circuit board carefully and try to only touch the power button you can see if the device works - it should be working without a screen.
    • There are many replacement screens available. You need to find a common cathode two digit (sometimes called two bit) 7 segment 0.4 inch display with white LEDs (LED colour is probably not important)
    • 0.4 inches refers to the short edge of the display
    • I found this one: https://www.aliexpress.com/item/10050085...
    • Which is ~£1 for 5 of them
    • Make sure it's got 10 pins - 5 on each side
5 other people completed this guide.
Alex Sadler
339 Reputation
1 Guide authored
10 Guide Comments
Thank you for putting this together! Followed the steps exactly and rescued one of these from it's journey to landfill. Works perfectly :)
Gabriel G - Reply
Great walk-through! Step 2 is the tricky part, the pulling force that is needed to remove the cover feels like things are going to break but all stayed in one piece. I managed to fix my Meaco Arete One which failed with exactly the same symptoms as described above. Only 1 year old and still under warranty but I decided to give it a try anyway (since the summer moist is arriving I didn't want to go through all the trouble of returning it and waiting for an unknown amount of time). It's running without display for the moment, waiting for the replacement part to arrive. Thanks again, great job!
GertE - Reply
Thank you for this guide! I managed to fix my unit myself
Jamie - Reply
jamie i got the same problem was going to ask if you could set me straight how to do this. please
vincent consenheim -
my display arrived today and ive taken the circuit board out from the top with allot of pulling , my friend will give me his solder iron tomorrow and then ill update you all
vincent consenheim - Reply
Past 24 Hours: 14
Past 7 Days: 119
Past 30 Days: 707
All Time: 6,806
