Meanwell SE-600-24 Fan Replacement
  1. Meanwell SE-600-24 Fan Replacement, Disassembly: step 1, image 1 of 3 Meanwell SE-600-24 Fan Replacement, Disassembly: step 1, image 2 of 3 Meanwell SE-600-24 Fan Replacement, Disassembly: step 1, image 3 of 3
    • There's 8 screws, 3 on each side and 2 on top. You need to remove to open the PSU. 1 of them is under the yellow sticker.
    • Slide the cover off.
  2. Meanwell SE-600-24 Fan Replacement, Disassembly: step 2, image 1 of 1
    • Remove the 5 screws that hold the board in to the case, than remove the board.
  3. Meanwell SE-600-24 Fan Replacement, Disassembly: step 3, image 1 of 2 Meanwell SE-600-24 Fan Replacement, Disassembly: step 3, image 2 of 2
    • Remove the 2 screws securing the fan to the casing.
    • Remove the fan.
    • Note the airflow arrows. When we put the new fan in we want to make sure the fan directs the air correctly.
  4. Meanwell SE-600-24 Fan Replacement, Wiring/Reassembly: step 4, image 1 of 3 Meanwell SE-600-24 Fan Replacement, Wiring/Reassembly: step 4, image 2 of 3 Meanwell SE-600-24 Fan Replacement, Wiring/Reassembly: step 4, image 3 of 3
    • The NF-A6x25 is a 4 wire PWM fan. Since we don't need all 4 wires cut the harness to length(12" should be enough).
    • Crimp on some JST 2.54 connectors.
    • 4 Pin fan: Yellow is 12v and Black is Ground
    • 3 Pin fan: Red is 12v and Black is ground
    • Mount the NF-A6x25 were the original fan was with the 2 screws that held in the Sunon fan. Make sure the airflow arrows point towards the board.
    • Insert the board into the case and secure it with the 5 screws.
    • Connect the NF-A6x25 fan to the board. Positive on the left and Negative on the right
    • Slide the casing cover on and the remaining 6 screws
I wasn’t paid to write these guides. Ben asked me to do it as a favor to him. Considering all that he’s done for our community I felt it was the least I could do. To be honest even though it took about 2 months to build and document, I had a lot of fun doing it. It forced me to write guides in a manner that was easy for everyone to understand and cleanup my Github so I could share any files that were used that aren’t part of the original download. You’re not obligated but if you would like, feel free to donate.
4 other people completed this guide.
David Husolo
9,132 Reputation
33 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 8
Past 30 Days: 33
All Time: 2,680
