Merangue Steel 3-Hole Punch Head Replacement
  1. Merangue Steel 3-Hole Punch Head Replacement, Punch Head: step 1, image 1 of 3 Merangue Steel 3-Hole Punch Head Replacement, Punch Head: step 1, image 2 of 3 Merangue Steel 3-Hole Punch Head Replacement, Punch Head: step 1, image 3 of 3
    • Tilt the hole puncher on its back.
    • Use a flathead screwdriver to remove the three screws.
  2. Merangue Steel 3-Hole Punch Head Replacement: step 2, image 1 of 3 Merangue Steel 3-Hole Punch Head Replacement: step 2, image 2 of 3 Merangue Steel 3-Hole Punch Head Replacement: step 2, image 3 of 3
    • Use your finger to slide the punch head out towards the opening (right in this case).
    • Remove the punch head from the opening and set it aside.
    • Repeat this step with the other punch heads.
  3. Merangue Steel 3-Hole Punch Head Replacement: step 3, image 1 of 3 Merangue Steel 3-Hole Punch Head Replacement: step 3, image 2 of 3 Merangue Steel 3-Hole Punch Head Replacement: step 3, image 3 of 3
    • Take your replacement hole punch and push it into the opening.
    • Slide the hole punch to your desired alignment in my case, left).
    • Make sure the hole punch is properly aligned (the hole at the back should point directly at the ceiling).
  4. Merangue Steel 3-Hole Punch Head Replacement: step 4, image 1 of 3 Merangue Steel 3-Hole Punch Head Replacement: step 4, image 2 of 3 Merangue Steel 3-Hole Punch Head Replacement: step 4, image 3 of 3
    • Use your fingers to screw one of the screws into the hole on the back of the punch head.
    • The screw can be a bit difficult to align so be patient and don't rush.
    • Take your flat head screwdriver and tighten the screw.
    • Repeat these steps for the other punch heads.
Finish Line
Noah Dela Calzada
109 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 10
All Time: 47
