Meta Quest 2 Heat Sink Replacement
  1. Meta Quest 2 Heat Sink Replacement, Power off your Meta Quest 2: step 1, image 1 of 1
    • Hold the power button for three seconds to fully turn off your headset.
    • You'll hear a power down chime, and the LED next to the power button will turn off.
  2. Meta Quest 2 Heat Sink Replacement, Remove the facial interface: step 2, image 1 of 2 Meta Quest 2 Heat Sink Replacement, Remove the facial interface: step 2, image 2 of 2
    • Grasp and pull on the nose section of the facial interface to unclip it from the headset.
  3. Meta Quest 2 Heat Sink Replacement: step 3, image 1 of 2 Meta Quest 2 Heat Sink Replacement: step 3, image 2 of 2
    • Grasp and pull on the top section of the facial interface to unclip it from the headset.
  4. Meta Quest 2 Heat Sink Replacement: step 4, image 1 of 1
    • Remove the facial interface.
    • During reassembly, align the facial interface to the headset and use your fingers to press along the perimeter to clip it back in.
  5. Meta Quest 2 Heat Sink Replacement, Unclip the side straps: step 5, image 1 of 3 Meta Quest 2 Heat Sink Replacement, Unclip the side straps: step 5, image 2 of 3 Meta Quest 2 Heat Sink Replacement, Unclip the side straps: step 5, image 3 of 3
    • Use your fingers to grasp the right strap near the headset.
    • Peel the right strap away from the headset arm to unclip it.
  6. Meta Quest 2 Heat Sink Replacement: step 6, image 1 of 2 Meta Quest 2 Heat Sink Replacement: step 6, image 2 of 2
    • Repeat the procedure to peel the left strap away from the arm to unclip it.
  7. Meta Quest 2 Heat Sink Replacement, Remove the top strap: step 7, image 1 of 2 Meta Quest 2 Heat Sink Replacement, Remove the top strap: step 7, image 2 of 2
    • Separate the hook and loop strip on the top strap.
  8. Meta Quest 2 Heat Sink Replacement, Remove the head strap: step 8, image 1 of 2 Meta Quest 2 Heat Sink Replacement, Remove the head strap: step 8, image 2 of 2
    • Unthread the top strap from its bracket.
    • Remove the head strap.
  9. Meta Quest 2 Heat Sink Replacement, Remove the eyepiece trim screws: step 9, image 1 of 2 Meta Quest 2 Heat Sink Replacement, Remove the eyepiece trim screws: step 9, image 2 of 2
    • Use a Torx T2 driver to remove the six 3.5 mm‑long screws securing the eyepiece trim.
  10. Meta Quest 2 Heat Sink Replacement, Release the eyepiece trim clips: step 10, image 1 of 2 Meta Quest 2 Heat Sink Replacement, Release the eyepiece trim clips: step 10, image 2 of 2
    • Insert an opening pick into the seam between the eyepiece trim and white outer shell, near the nose cutout.
  11. Meta Quest 2 Heat Sink Replacement: step 11, image 1 of 3 Meta Quest 2 Heat Sink Replacement: step 11, image 2 of 3 Meta Quest 2 Heat Sink Replacement: step 11, image 3 of 3
    • Slide the opening pick to the right along the seam to release the clips securing the eyepiece trim.
    • Pry with the opening pick to release the clips securing the right side of the eyepiece trim.
    • Leave the opening pick in the seam to prevent the clips from reengaging.
  12. Meta Quest 2 Heat Sink Replacement: step 12, image 1 of 3 Meta Quest 2 Heat Sink Replacement: step 12, image 2 of 3 Meta Quest 2 Heat Sink Replacement: step 12, image 3 of 3
    • Repeat the prying procedure along the left edge to release the clips securing the eyepiece trim.
    • During reassembly, press your fingers along the perimeter of the eyepiece trim to clip it back in place.
  13. Meta Quest 2 Heat Sink Replacement, Reposition the eyepiece trim: step 13, image 1 of 3 Meta Quest 2 Heat Sink Replacement, Reposition the eyepiece trim: step 13, image 2 of 3 Meta Quest 2 Heat Sink Replacement, Reposition the eyepiece trim: step 13, image 3 of 3
    • Don’t try to fully remove the eyepiece trim in this step. It’s still connected to the headset by a short cable.
    • Lift the eyepiece trim slightly and tilt it towards the top edge of the headset.
    • Set the trim down on your work surface, making sure not to strain the cable.
  14. Meta Quest 2 Heat Sink Replacement, Disconnect the face sensor: step 14, image 1 of 3 Meta Quest 2 Heat Sink Replacement, Disconnect the face sensor: step 14, image 2 of 3 Meta Quest 2 Heat Sink Replacement, Disconnect the face sensor: step 14, image 3 of 3
    • Use the point of a spudger to flip open the black lock tab on the ZIF connector securing the face sensor cable.
  15. Meta Quest 2 Heat Sink Replacement: step 15, image 1 of 2 Meta Quest 2 Heat Sink Replacement: step 15, image 2 of 2
    Tool used on this step:
    Buy
    • Use tweezers to pull the face sensor cable out of the ZIF connector.
  16. Meta Quest 2 Heat Sink Replacement, Remove the eyepiece trim: step 16, image 1 of 1
    • Remove the eyepiece trim.
  17. Meta Quest 2 Heat Sink Replacement, Reassembly note: step 17, image 1 of 2 Meta Quest 2 Heat Sink Replacement, Reassembly note: step 17, image 2 of 2
    • During reassembly:
    • Make sure the lens spacing matches the spacing indicator. This allows the indicator peg to sit correctly in its notch.
    • If the lens spacing doesn't match the indicator, manually adjust the lens with your fingers.
  18. Meta Quest 2 Heat Sink Replacement, Reassembly note: step 18, image 1 of 3 Meta Quest 2 Heat Sink Replacement, Reassembly note: step 18, image 2 of 3 Meta Quest 2 Heat Sink Replacement, Reassembly note: step 18, image 3 of 3
    • During reassembly, the face sensor cable can be tricky to connect. Follow these tips to connect the cable:
    • Thread your fingers through the eyepiece trim’s eyeholes and grasp the edges of the sensor cable.
    • Slide the sensor cable into the socket until the first set of tabs rests in the socket. This should flip the lock tab down partially.
    • Use a spudger to press the lock tab down towards the cable to lock it in place.
  19. Meta Quest 2 Heat Sink Replacement, Remove the front cover screws: step 19, image 1 of 3 Meta Quest 2 Heat Sink Replacement, Remove the front cover screws: step 19, image 2 of 3 Meta Quest 2 Heat Sink Replacement, Remove the front cover screws: step 19, image 3 of 3
    • Use a Phillips screwdriver to remove the five 7.7 mm‑long screws securing the front cover to the headset:
    • One recessed in the top-left corner
    • One recessed in the top-right corner
    • Three along the lower edge
  20. Meta Quest 2 Heat Sink Replacement, Release the front cover clips: step 20, image 1 of 2 Meta Quest 2 Heat Sink Replacement, Release the front cover clips: step 20, image 2 of 2
    • The front cover is still held in place by clips along the bottom and side edges.
    • Insert an opening pick into the seam between the bottom edge of the front cover and the headset.
    • Pry with the opening pick to release the front cover clips.
  21. Meta Quest 2 Heat Sink Replacement: step 21, image 1 of 3 Meta Quest 2 Heat Sink Replacement: step 21, image 2 of 3 Meta Quest 2 Heat Sink Replacement: step 21, image 3 of 3
    • Slide the opening clip along the seam and pry to release all the clips securing the front cover.
  22. Meta Quest 2 Heat Sink Replacement, Remove the front cover: step 22, image 1 of 1
    • Remove the front cover.
  23. Meta Quest 2 Heat Sink Replacement, Disconnect the top right antenna: step 23, image 1 of 3 Meta Quest 2 Heat Sink Replacement, Disconnect the top right antenna: step 23, image 2 of 3 Meta Quest 2 Heat Sink Replacement, Disconnect the top right antenna: step 23, image 3 of 3
    Buy
    • Use a pair of tweezers to grasp the metal neck of the top-right antenna cable.
    • Lift the antenna connector straight up to disconnect it.
    • Guide the antenna cable out of its metal clip holding it in place.
  24. Meta Quest 2 Heat Sink Replacement, Remove the battery cable bracket: step 24, image 1 of 1
    • Use a Phillips screwdriver to remove the three screws securing the battery cable bracket:
    • One 4.4 mm‑long screw
    • Two 2.3 mm‑long screws
  25. Meta Quest 2 Heat Sink Replacement: step 25, image 1 of 3 Meta Quest 2 Heat Sink Replacement: step 25, image 2 of 3 Meta Quest 2 Heat Sink Replacement: step 25, image 3 of 3
    • Use tweezers or your fingers to grasp the battery cable bracket.
    • Twist the cable bracket slightly so that its bottom left corner unclips from the motherboard.
    • Remove the battery cable bracket.
  26. Meta Quest 2 Heat Sink Replacement, Disconnect the battery: step 26, image 1 of 2 Meta Quest 2 Heat Sink Replacement, Disconnect the battery: step 26, image 2 of 2
    • Use a spudger to pry up and disconnect the battery press connector from the motherboard.
    • The battery press connector can disconnect accidentally during reassembly. Check this connector before you attach the bracket.
  27. Meta Quest 2 Heat Sink Replacement, Disconnect the antenna: step 27, image 1 of 3 Meta Quest 2 Heat Sink Replacement, Disconnect the antenna: step 27, image 2 of 3 Meta Quest 2 Heat Sink Replacement, Disconnect the antenna: step 27, image 3 of 3
    Buy
    • Insert one arm of a pair of tweezers under the metal neck of the black antenna cable near the fan assembly.
  28. Meta Quest 2 Heat Sink Replacement, Loosen the front antenna assembly: step 28, image 1 of 2 Meta Quest 2 Heat Sink Replacement, Loosen the front antenna assembly: step 28, image 2 of 2
    • Use a Phillips screwdriver to remove the eight screws securing the antenna assembly to the headset:
    • Four 4.4 mm‑long screws
    • Two 4.8 mm‑long screws
    • Two 10.7 mm‑long screws
  29. Meta Quest 2 Heat Sink Replacement: step 29, image 1 of 2 Meta Quest 2 Heat Sink Replacement: step 29, image 2 of 2
    • Use your fingers to flip up the antenna assembly enough to access the cable underneath it.
  30. Meta Quest 2 Heat Sink Replacement: step 30, image 1 of 2 Meta Quest 2 Heat Sink Replacement: step 30, image 2 of 2
    • Use tweezers to unclip the antenna cable from its metal clip.
  31. Meta Quest 2 Heat Sink Replacement, Remove the front antenna assembly: step 31, image 1 of 1
    • Remove the front antenna assembly.
  32. Meta Quest 2 Heat Sink Replacement, Disconnect the fan: step 32, image 1 of 2 Meta Quest 2 Heat Sink Replacement, Disconnect the fan: step 32, image 2 of 2
    Buy
    • Use tweezers to grab the fan connector and carefully slide it out of its socket.
  33. Meta Quest 2 Heat Sink Replacement, Loosen the LED flex cable: step 33, image 1 of 2 Meta Quest 2 Heat Sink Replacement, Loosen the LED flex cable: step 33, image 2 of 2
    • Use the point of an opening pick to loosen the adhesive securing the LED flex cable from the top of the fan assembly.
  34. Meta Quest 2 Heat Sink Replacement, Remove the fan assembly: step 34, image 1 of 1
    • Remove the two screws securing the fan assembly to the headset:
    • One 4.4 mm‑long Phillips screw
    • One 3.6 mm‑long Torx T2 screw
  35. Meta Quest 2 Heat Sink Replacement: step 35, image 1 of 3 Meta Quest 2 Heat Sink Replacement: step 35, image 2 of 3 Meta Quest 2 Heat Sink Replacement: step 35, image 3 of 3
    • Lift the fan assembly and remove it.
  36. Meta Quest 2 Heat Sink Replacement, Remove the heat sink: step 36, image 1 of 1
    • Use a Phillips screwdriver to remove the four 2.3 mm‑long screws securing the heat sink to the motherboard.
  37. Meta Quest 2 Heat Sink Replacement: step 37, image 1 of 2 Meta Quest 2 Heat Sink Replacement: step 37, image 2 of 2
    • Use your fingers to lift the heat sink and remove it.
    • You may feel a bit of resistance. This is normal since the midframe is slightly bonded to the heat sink with thermal paste.
    • You can reuse the thermal paste if you keep it clean. Otherwise, use a spudger to scrape off the old paste and apply a small amount of viscous thermal compound (such as K5 Pro) to the processor.
Arthur Shi
257,458 Reputation
529 Guides authored
iFixit Member of iFixit
Staff
141 Members
17,895 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 47
All Time: 237
