Video Overview
This teardown is not a repair guide. To repair your Meta Quest 3, use our service manual.
  1. Meta Quest 3 Chip ID, Headset Board Side 1: step 1, image 1 of 2 Meta Quest 3 Chip ID, Headset Board Side 1: step 1, image 2 of 2
    • Qualcomm SXR2230P-100-AB Snapdragon XR2 gen 2 applications processor
    • Likely SK hynix H58G66BK8BX105 8 GB LPDDR5 SDRAM memory
    • AKM Semiconductor AK4333ECB 32-bit stereo audio D/A converter
    • Probably Triad Semiconductor TS5231 IR analog front end
  2. Meta Quest 3 Chip ID, Headset Board Side 1 - Connectivity: step 2, image 1 of 1
    • Qualcomm WCN6856-102 Wi-Fi 6E SoC
    • Qorvo QM42391 2.4 GHz Wi-Fi 6E front-end module
    • Qorvo QM45392 5 GHz Wi-Fi 6E front end module
    • Nordic Semiconductor nRF52833 Bluetooth Low-Energy 5.4 SoC
  3. Meta Quest 3 Chip ID, Headset Board Side 2: step 3, image 1 of 2 Meta Quest 3 Chip ID, Headset Board Side 2: step 3, image 2 of 2
    • SK hynix HN8T05DEHKX073 128 GB NAND flash memory
    • Qualcomm PMXR2230B-001 power management
    • Qualcomm PMXR2230-001 power management
    • Qualcomm PMXR2230VE-001 power management
    • Qualcomm PMXR2230VS-001 power management
    • Likely Qualcomm clock generator
    • STMicroelectronics STM32G071EB 32-bit ARM Cortex-M0+ microcontroller
  4. Meta Quest 3 Chip ID: step 4, image 1 of 1
    • Silicon Labs EFM8BB51F8G 8-bit microcontroller
    • Infineon CYPD3177-24LQXQ USB Type-C port controller
    • Analog Devices MAX98388 mono class-D audio amplifier
    • Texas Instruments TPS65132L dual output power supply
    • SG Micro SGM62110 2.5 A buck-boost converter
    • STMicroelectronics LM324QT quad operational amplifier
  5. Meta Quest 3 Chip ID, Controller Board Side 1: step 5, image 1 of 2 Meta Quest 3 Chip ID, Controller Board Side 1: step 5, image 2 of 2
    • Microchip ATSAMD21G17D 32-bit ARM Cortex-M0+ microcontroller
    • Analog Devices MAX98361AEWL+ 3.2 W audio amplifier
    • SG Micro SGM6601 DC-DC boost converter
    • Monolithic Power Systems MP3414 1.8 A synchronous step-up converter
  6. Meta Quest 3 Chip ID, Controller Board Side 1 - Connectivity: step 6, image 1 of 1
    • Nordic Semiconductor nRF52820 Bluetooth Low-Energy 5.4 SoC
  7. Meta Quest 3 Chip ID, Controller Board Side 1 - Sensors: step 7, image 1 of 1
    • TDK-InvenSense ICM-42686-P 6-axis accelerometer & gyroscope
    • Allegro MicroSystems A1392 hall effect sensor
    • Allegro MicroSystems A1393 hall effect sensor
4 Guide Comments
Do you have any information on Quest 3's depth sensor?
黑毛警长 - Reply
I have a guess: it could be the new VD55H1 from STMicroelectronics. For my own project I want to use the VL53L5CX, a much simpler sensor.
Tobias Platen - Reply
I've tried to find more information about the TDK-InvenSense ICM-42686-P 6-axis accelerometer & gyroscope..
But I have only found information and a place to order replacement model ICM-42688-P. Do any of you know of these are the same?
Luke Guy - Reply
Are you saying there is no IMU on the main board?!?!
Mr Bean - Reply
Past 24 Hours: 13
Past 7 Days: 118
Past 30 Days: 545
All Time: 14,400
