Metal Snap Installation Using a Hand Press
  1. Metal Snap Installation Using a Hand Press, Metal snap types: step 1, image 1 of 2 Metal Snap Installation Using a Hand Press, Metal snap types: step 1, image 2 of 2
    • There are two main styles of metal snaps on Patagonia gear:
    • Flat Spring Snap - This style is commonly found on clothing because it snaps and unsnaps smoothly.
    • Durable Socket Snap - This style is commonly found on packs and luggage because it has thicker metal that can withstand heavy use.
    • Each piece of the snap has its own corresponding snap die. Make sure you use the correct size and style of snap.
  2. Metal Snap Installation Using a Hand Press, Gather the pieces for a metal snap base: step 2, image 1 of 2 Metal Snap Installation Using a Hand Press, Gather the pieces for a metal snap base: step 2, image 2 of 2
    • This tutorial will demonstrate with the Durable Socket Snap, but the same actions can be applied to the Flat Spring Snap.
    • Gather the stud and post pieces and their corresponding dies.
    • The stud and post are compressed together with the press to create the base of the snap.
  3. Metal Snap Installation Using a Hand Press, Insert the post into the post die: step 3, image 1 of 3 Metal Snap Installation Using a Hand Press, Insert the post into the post die: step 3, image 2 of 3 Metal Snap Installation Using a Hand Press, Insert the post into the post die: step 3, image 3 of 3
    • Insert the post piece into the post die so the flat part of the post sits inside the die with the shaft pointed out.
  4. Metal Snap Installation Using a Hand Press, Insert the post die into the hand press: step 4, image 1 of 2 Metal Snap Installation Using a Hand Press, Insert the post die into the hand press: step 4, image 2 of 2
    • Insert the post die into the lower fitting of the hand press.
  5. Metal Snap Installation Using a Hand Press, Insert the stud into the stud die: step 5, image 1 of 3 Metal Snap Installation Using a Hand Press, Insert the stud into the stud die: step 5, image 2 of 3 Metal Snap Installation Using a Hand Press, Insert the stud into the stud die: step 5, image 3 of 3
    • Insert the stud piece into the stud die until it snaps into place.
  6. Metal Snap Installation Using a Hand Press, Insert the stud die into the hand press: step 6, image 1 of 3 Metal Snap Installation Using a Hand Press, Insert the stud die into the hand press: step 6, image 2 of 3 Metal Snap Installation Using a Hand Press, Insert the stud die into the hand press: step 6, image 3 of 3
    • Using your fingers, a screwdriver, or a hex key, as needed, unscrew the tightening mechanism on the side of the press near the die fitting.
    • Insert the die upward and hold it in place.
    • Tighten the tightening mechanism.
  7. Metal Snap Installation Using a Hand Press, Install the snap base: step 7, image 1 of 3 Metal Snap Installation Using a Hand Press, Install the snap base: step 7, image 2 of 3 Metal Snap Installation Using a Hand Press, Install the snap base: step 7, image 3 of 3
    • Lay the item to be repaired into the hand press so that the hole from the original snap rests directly above the shaft of the post.
    • If the fabric around the old snap is torn or damaged beyond a small hole, apply a patch to reinforce the area before replacing the snap.
    • Make sure no extra fabric is caught inside the press and that the orientation of the item is correct.
    • Hold the fabric in place with one hand, then use your other hand to pull down the handle of the press.
    • This requires a lot of pressure to make sure the snap replacement is successful - so pull hard!
  8. Metal Snap Installation Using a Hand Press, Quality control: step 8, image 1 of 2 Metal Snap Installation Using a Hand Press, Quality control: step 8, image 2 of 2
    • Release the handle of the hand press and remove the fabric.
    • Inspect both sides of the snap to make sure:
    • It's laying flat and tight up against the fabric.
    • It doesn't spin in place.
    • It fastens together securely with the head of the snap.
    • If the snap isn't set all the way, reinsert the snap into the hand press, aligning it as it was before, and pull the handle again.
  9. Metal Snap Installation Using a Hand Press, Gather the pieces for a metal snap head: step 9, image 1 of 2 Metal Snap Installation Using a Hand Press, Gather the pieces for a metal snap head: step 9, image 2 of 2
    • Gather the socket and cap pieces and their corresponding dies.
    • The socket and cap are compressed together with the press to create the head of the snap.
  10. Metal Snap Installation Using a Hand Press, Insert the cap into the cap die: step 10, image 1 of 3 Metal Snap Installation Using a Hand Press, Insert the cap into the cap die: step 10, image 2 of 3 Metal Snap Installation Using a Hand Press, Insert the cap into the cap die: step 10, image 3 of 3
    • Insert the cap piece into the cap die so it sits inside the die with the shaft facing out.
  11. Metal Snap Installation Using a Hand Press, Insert the cap die into the hand press: step 11, image 1 of 3 Metal Snap Installation Using a Hand Press, Insert the cap die into the hand press: step 11, image 2 of 3 Metal Snap Installation Using a Hand Press, Insert the cap die into the hand press: step 11, image 3 of 3
    • Insert the cap die into the lower fitting of the hand press.
  12. Metal Snap Installation Using a Hand Press, Insert the socket into the socket die: step 12, image 1 of 2 Metal Snap Installation Using a Hand Press, Insert the socket into the socket die: step 12, image 2 of 2
    • Insert the socket piece into the socket die until it snaps into place.
  13. Metal Snap Installation Using a Hand Press, Insert the socket die into the hand press: step 13, image 1 of 3 Metal Snap Installation Using a Hand Press, Insert the socket die into the hand press: step 13, image 2 of 3 Metal Snap Installation Using a Hand Press, Insert the socket die into the hand press: step 13, image 3 of 3
  14. Metal Snap Installation Using a Hand Press, Install the snap head: step 14, image 1 of 3 Metal Snap Installation Using a Hand Press, Install the snap head: step 14, image 2 of 3 Metal Snap Installation Using a Hand Press, Install the snap head: step 14, image 3 of 3
  15. Metal Snap Installation Using a Hand Press, Quality control: step 15, image 1 of 2 Metal Snap Installation Using a Hand Press, Quality control: step 15, image 2 of 2
    • It fastens together securely with the base of the snap.
  16. Metal Snap Installation Using a Hand Press, Examples: step 16, image 1 of 2 Metal Snap Installation Using a Hand Press, Examples: step 16, image 2 of 2
    • The rain jacket in the first photo has flat spring metal snaps along the center front zipper placket.
    • The duffel bag in the second photo has durable socket metal snaps at the handle grip.
Finish Line
3 other people completed this guide.
Brittany McCrigler
90,519 Reputation
142 Guides authored
iFixit Member of iFixit
Staff
123 Members
23,828 Guides authored
0 Guide Comments
Past 24 Hours: 14
Past 7 Days: 81
Past 30 Days: 326
All Time: 23,194
