Mi-T-M Heater MH-0190 Spark Plug Replacement
  1. Mi-T-M Heater MH-0190 Spark Plug Replacement, Safety precautions: step 1, image 1 of 2 Mi-T-M Heater MH-0190 Spark Plug Replacement, Safety precautions: step 1, image 2 of 2
    • Power off the machine at least one hour prior to starting repairs. Ensure the machine is completely cool to the touch.
    • Flip the power switch into the OFF position.
    • Unplug any extension cords from the included power cord.
  2. Mi-T-M Heater MH-0190 Spark Plug Replacement, Remove the upper shell: step 2, image 1 of 2 Mi-T-M Heater MH-0190 Spark Plug Replacement, Remove the upper shell: step 2, image 2 of 2
    • Use a 5/16 inch socket or Phillips screwdriver to remove the eight screws securing the upper shell, four on each side.
  3. Mi-T-M Heater MH-0190 Spark Plug Replacement: step 3, image 1 of 2 Mi-T-M Heater MH-0190 Spark Plug Replacement: step 3, image 2 of 2
    • Lift the upper shell straight up off of the machine to remove it.
  4. Mi-T-M Heater MH-0190 Spark Plug Replacement, Disconnect the spark plug wires: step 4, image 1 of 3 Mi-T-M Heater MH-0190 Spark Plug Replacement, Disconnect the spark plug wires: step 4, image 2 of 3 Mi-T-M Heater MH-0190 Spark Plug Replacement, Disconnect the spark plug wires: step 4, image 3 of 3
    • Grab the spark plug wires by their boots and pull firmly to disconnect them from the spark plug.
  5. Mi-T-M Heater MH-0190 Spark Plug Replacement, Remove the spark plug: step 5, image 1 of 1
    • Use a 5/16 inch socket or Phillips screwdriver to remove the bolt securing the spark plug.
    • During reassembly, install the insulating washer against the spark plug and the lock washer against the bolt.
  6. Mi-T-M Heater MH-0190 Spark Plug Replacement: step 6, image 1 of 3 Mi-T-M Heater MH-0190 Spark Plug Replacement: step 6, image 2 of 3 Mi-T-M Heater MH-0190 Spark Plug Replacement: step 6, image 3 of 3
    • Remove the spark plug.
    • During reassembly, insert the new spark plug with the leads angled towards the center of the combustion chamber.
Sam Omiotek
83,736 Reputation
290 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 7
All Time: 332
