Mi-T-M Heater MH-0190-0M10 Ignitor Replacement
  1. Mi-T-M Heater MH-0190-0M10 Ignitor Replacement, Safety precautions: step 1, image 1 of 2 Mi-T-M Heater MH-0190-0M10 Ignitor Replacement, Safety precautions: step 1, image 2 of 2
    • Power off the machine at least one hour prior to starting repairs. Ensure the machine is completely cool to the touch.
    • Flip the power switch into the OFF position.
    • Unplug any extension cords from the included power cord.
  2. Mi-T-M Heater MH-0190-0M10 Ignitor Replacement, Remove the upper shell: step 2, image 1 of 2 Mi-T-M Heater MH-0190-0M10 Ignitor Replacement, Remove the upper shell: step 2, image 2 of 2
    • Use a 5/16 inch socket or Phillips screwdriver to remove the eight screws securing the upper shell, four on each side.
  3. Mi-T-M Heater MH-0190-0M10 Ignitor Replacement: step 3, image 1 of 2 Mi-T-M Heater MH-0190-0M10 Ignitor Replacement: step 3, image 2 of 2
    • Lift the upper shell straight up off of the machine to remove it.
  4. Mi-T-M Heater MH-0190-0M10 Ignitor Replacement, Remove the right-side cover: step 4, image 1 of 1
    • Use a 5/16 inch socket or Phillips screwdriver to remove the four bolts securing the right-side cover.
  5. Mi-T-M Heater MH-0190-0M10 Ignitor Replacement: step 5, image 1 of 3 Mi-T-M Heater MH-0190-0M10 Ignitor Replacement: step 5, image 2 of 3 Mi-T-M Heater MH-0190-0M10 Ignitor Replacement: step 5, image 3 of 3
    • Tilt the right-side cover down to access the PCB board.
    • Do not fully remove the right-side cover, it is still attached via the on/off switch.
    • During reassembly, ensure the display window is aligned with the LCD display before you press the cover into place.
  6. Mi-T-M Heater MH-0190-0M10 Ignitor Replacement: step 6, image 1 of 3 Mi-T-M Heater MH-0190-0M10 Ignitor Replacement: step 6, image 2 of 3 Mi-T-M Heater MH-0190-0M10 Ignitor Replacement: step 6, image 3 of 3
    • There are two wires connecting the power switch to the main PCB assembly.
    • Use needle nose pliers to remove the wire with the blue connector.
    • Remove the wire with the clear connector.
    • Remove the right-side cover.
    • During reassembly, install the power switch wires back in their original locations with the blue wire above the clear wire.
  7. Mi-T-M Heater MH-0190-0M10 Ignitor Replacement, Disconnect the ground wires: step 7, image 1 of 1
    • Use a 5/16 inch socket or Phillips screwdriver to remove the screw securing the two green ground wires to the frame.
  8. Mi-T-M Heater MH-0190-0M10 Ignitor Replacement, Disconnect the fuel line: step 8, image 1 of 3 Mi-T-M Heater MH-0190-0M10 Ignitor Replacement, Disconnect the fuel line: step 8, image 2 of 3 Mi-T-M Heater MH-0190-0M10 Ignitor Replacement, Disconnect the fuel line: step 8, image 3 of 3
    • Use a pair of needle nose pliers to release the hose clamp from the fuel line.
    • Slide the hose clamp off of the nipple, about one inch down the fuel line.
  9. Mi-T-M Heater MH-0190-0M10 Ignitor Replacement: step 9, image 1 of 2 Mi-T-M Heater MH-0190-0M10 Ignitor Replacement: step 9, image 2 of 2
    • Pull to disconnect the fuel line from the motor and pump assembly.
  10. Mi-T-M Heater MH-0190-0M10 Ignitor Replacement: step 10, image 1 of 2 Mi-T-M Heater MH-0190-0M10 Ignitor Replacement: step 10, image 2 of 2
    • Use a pair of needle nose pliers to remove the fuel line hose clamp.
  11. Mi-T-M Heater MH-0190-0M10 Ignitor Replacement, Disconnect the motor and pump assembly: step 11, image 1 of 2 Mi-T-M Heater MH-0190-0M10 Ignitor Replacement, Disconnect the motor and pump assembly: step 11, image 2 of 2
    • Use a pair of needle nose pliers to disconnect the wires connecting the motor and pump assembly to the main PCB board:
    • One red cable labeled MOTOR 2 on the main PCB board
    • One orange cable labeled MOTOR 1 on the main PCB board
    • Pull the wires with the needle nose pliers by their connectors and not the wires themselves.
  12. Mi-T-M Heater MH-0190-0M10 Ignitor Replacement: step 12, image 1 of 3 Mi-T-M Heater MH-0190-0M10 Ignitor Replacement: step 12, image 2 of 3 Mi-T-M Heater MH-0190-0M10 Ignitor Replacement: step 12, image 3 of 3
    • Use a pair of flush cutters to cut the cable tie harnessing the wires running from the main PCB assembly.
    • Remove the cable tie.
    • During reassembly, install a new cable tie.
  13. Mi-T-M Heater MH-0190-0M10 Ignitor Replacement: step 13, image 1 of 2 Mi-T-M Heater MH-0190-0M10 Ignitor Replacement: step 13, image 2 of 2
    • Use a pair of flush cutters to cut the cable tie harnessing the orange, red, white, and black wires near the fuel line.
  14. Mi-T-M Heater MH-0190-0M10 Ignitor Replacement: step 14, image 1 of 2 Mi-T-M Heater MH-0190-0M10 Ignitor Replacement: step 14, image 2 of 2
    • Use a pair of flush cutters to cut the cable tie harnessing the orange and red wires next to the motor.
  15. Mi-T-M Heater MH-0190-0M10 Ignitor Replacement, Detach the capacitor: step 15, image 1 of 1
    • Use a Phillips screwdriver to remove the screw securing the capacitor band clamp.
  16. Mi-T-M Heater MH-0190-0M10 Ignitor Replacement: step 16, image 1 of 3 Mi-T-M Heater MH-0190-0M10 Ignitor Replacement: step 16, image 2 of 3 Mi-T-M Heater MH-0190-0M10 Ignitor Replacement: step 16, image 3 of 3
    • Remove the capacitor from the band clamp.
    • During reassembly, realign the foam padding between the capacitor and the band clamp.
  17. Mi-T-M Heater MH-0190-0M10 Ignitor Replacement, Remove the motor and pump assembly: step 17, image 1 of 3 Mi-T-M Heater MH-0190-0M10 Ignitor Replacement, Remove the motor and pump assembly: step 17, image 2 of 3 Mi-T-M Heater MH-0190-0M10 Ignitor Replacement, Remove the motor and pump assembly: step 17, image 3 of 3
    • Feed the orange and red wires out through the opening in the lower shell.
  18. Mi-T-M Heater MH-0190-0M10 Ignitor Replacement: step 18, image 1 of 1
    • Use a 5/16 inch socket or Phillips screwdriver to remove the four bolts securing the left-side cover.
  19. Mi-T-M Heater MH-0190-0M10 Ignitor Replacement: step 19, image 1 of 3 Mi-T-M Heater MH-0190-0M10 Ignitor Replacement: step 19, image 2 of 3 Mi-T-M Heater MH-0190-0M10 Ignitor Replacement: step 19, image 3 of 3
    • Remove the left-side cover.
  20. Mi-T-M Heater MH-0190-0M10 Ignitor Replacement: step 20, image 1 of 2 Mi-T-M Heater MH-0190-0M10 Ignitor Replacement: step 20, image 2 of 2
    • Use a 5/16 inch socket or Phillips screwdriver to remove the four screws securing the motor mount bracket, two on each side.
  21. Mi-T-M Heater MH-0190-0M10 Ignitor Replacement: step 21, image 1 of 2 Mi-T-M Heater MH-0190-0M10 Ignitor Replacement: step 21, image 2 of 2
    • Lift the motor, pump, and bracket assembly straight up out of the machine.
  22. Mi-T-M Heater MH-0190-0M10 Ignitor Replacement, Disconnect the spark plug wires: step 22, image 1 of 3 Mi-T-M Heater MH-0190-0M10 Ignitor Replacement, Disconnect the spark plug wires: step 22, image 2 of 3 Mi-T-M Heater MH-0190-0M10 Ignitor Replacement, Disconnect the spark plug wires: step 22, image 3 of 3
    • Grab the spark plug wires by their boots and pull firmly to disconnect them from the spark plug.
  23. Mi-T-M Heater MH-0190-0M10 Ignitor Replacement: step 23, image 1 of 3 Mi-T-M Heater MH-0190-0M10 Ignitor Replacement: step 23, image 2 of 3 Mi-T-M Heater MH-0190-0M10 Ignitor Replacement: step 23, image 3 of 3
    • Feed the wires through the opening in the lower shell.
  24. Mi-T-M Heater MH-0190-0M10 Ignitor Replacement, Disconnect the ignitor from the main PCB assembly: step 24, image 1 of 3 Mi-T-M Heater MH-0190-0M10 Ignitor Replacement, Disconnect the ignitor from the main PCB assembly: step 24, image 2 of 3 Mi-T-M Heater MH-0190-0M10 Ignitor Replacement, Disconnect the ignitor from the main PCB assembly: step 24, image 3 of 3
    • Use a pair of needle nose pliers to depress the locking tab on the red wiring harness's connector labeled IG on the main PCB assembly.
    • With the locking tab depressed, pull to remove the red wire from its header on the PCB.
  25. Mi-T-M Heater MH-0190-0M10 Ignitor Replacement, Remove the igniter: step 25, image 1 of 3 Mi-T-M Heater MH-0190-0M10 Ignitor Replacement, Remove the igniter: step 25, image 2 of 3 Mi-T-M Heater MH-0190-0M10 Ignitor Replacement, Remove the igniter: step 25, image 3 of 3
    • Use your fingers to bend the metal tab on the lower shell holding the igniter in place upward to create space for the igniter to be removed.
    • During reassembly, bend the tab back into place once the new igniter is installed.
  26. Mi-T-M Heater MH-0190-0M10 Ignitor Replacement: step 26, image 1 of 3 Mi-T-M Heater MH-0190-0M10 Ignitor Replacement: step 26, image 2 of 3 Mi-T-M Heater MH-0190-0M10 Ignitor Replacement: step 26, image 3 of 3
    • Lift the igniter out from underneath the lower shell.
  27. Mi-T-M Heater MH-0190-0M10 Ignitor Replacement: step 27, image 1 of 2 Mi-T-M Heater MH-0190-0M10 Ignitor Replacement: step 27, image 2 of 2
    • Feed the red wire harness through the opening in the lower shell.
  28. Mi-T-M Heater MH-0190-0M10 Ignitor Replacement: step 28, image 1 of 3 Mi-T-M Heater MH-0190-0M10 Ignitor Replacement: step 28, image 2 of 3 Mi-T-M Heater MH-0190-0M10 Ignitor Replacement: step 28, image 3 of 3
    • Remove the spark plug wires from underneath the lower shell.
    • Remove the igniter.
Sam Omiotek
76,055 Reputation
288 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 3
All Time: 178
