Mi-T-M Heater MH-0190-0M10 Photocell Replacement
  1. Mi-T-M Heater MH-0190-0M10 Photocell Replacement, Safety precautions: step 1, image 1 of 2 Mi-T-M Heater MH-0190-0M10 Photocell Replacement, Safety precautions: step 1, image 2 of 2
    • Power off the machine at least one hour prior to starting repairs. Ensure the machine is completely cool to the touch.
    • Flip the power switch into the OFF position.
    • Unplug any extension cords from the included power cord.
  2. Mi-T-M Heater MH-0190-0M10 Photocell Replacement, Remove the upper shell: step 2, image 1 of 2 Mi-T-M Heater MH-0190-0M10 Photocell Replacement, Remove the upper shell: step 2, image 2 of 2
    • Use a 5/16 inch socket or Phillips screwdriver to remove the eight screws securing the upper shell, four on each side.
  3. Mi-T-M Heater MH-0190-0M10 Photocell Replacement: step 3, image 1 of 2 Mi-T-M Heater MH-0190-0M10 Photocell Replacement: step 3, image 2 of 2
    • Lift the upper shell straight up off of the machine to remove it.
  4. Mi-T-M Heater MH-0190-0M10 Photocell Replacement, Remove the right-side cover: step 4, image 1 of 1
    • Use a 5/16 inch socket or Phillips screwdriver to remove the four bolts securing the right-side cover.
  5. Mi-T-M Heater MH-0190-0M10 Photocell Replacement: step 5, image 1 of 3 Mi-T-M Heater MH-0190-0M10 Photocell Replacement: step 5, image 2 of 3 Mi-T-M Heater MH-0190-0M10 Photocell Replacement: step 5, image 3 of 3
    • Tilt the right-side cover down to access the PCB board.
    • Do not fully remove the right-side cover, it is still attached via the on/off switch.
    • During reassembly, ensure the display window is aligned with the LCD display before you press the cover into place.
  6. Mi-T-M Heater MH-0190-0M10 Photocell Replacement: step 6, image 1 of 3 Mi-T-M Heater MH-0190-0M10 Photocell Replacement: step 6, image 2 of 3 Mi-T-M Heater MH-0190-0M10 Photocell Replacement: step 6, image 3 of 3
    • There are two wires connecting the power switch to the main PCB assembly.
    • Use needle nose pliers to remove the wire with the blue connector.
    • Remove the wire with the clear connector.
    • Remove the right-side cover.
    • During reassembly, install the power switch wires back in their original locations with the blue wire above the clear wire.
  7. Mi-T-M Heater MH-0190-0M10 Photocell Replacement, Remove the photocell: step 7, image 1 of 2 Mi-T-M Heater MH-0190-0M10 Photocell Replacement, Remove the photocell: step 7, image 2 of 2
    • Use your fingers to disconnect the white wire harness labeled CN3 on the main PCB assembly.
  8. Mi-T-M Heater MH-0190-0M10 Photocell Replacement: step 8, image 1 of 3 Mi-T-M Heater MH-0190-0M10 Photocell Replacement: step 8, image 2 of 3 Mi-T-M Heater MH-0190-0M10 Photocell Replacement: step 8, image 3 of 3
    • Use your fingers or a pair of pliers to remove the photocell from its bracket.
    • During reassembly, ensure the photocell sits flush around the entire perimeter of the bracket.
  9. Mi-T-M Heater MH-0190-0M10 Photocell Replacement: step 9, image 1 of 3 Mi-T-M Heater MH-0190-0M10 Photocell Replacement: step 9, image 2 of 3 Mi-T-M Heater MH-0190-0M10 Photocell Replacement: step 9, image 3 of 3
    • Feed the photocell wires through the opening in the lower cover.
    • Remove the photocell.
Sam Omiotek
76,055 Reputation
288 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 121
