MiTM Air Compressors AM1HE0205HD 2014 Power Cord Replacement
  1. MiTM Air Compressors AM1HE0205HD 2014 Power Cord Replacement, Power off the compressor: step 1, image 1 of 2 MiTM Air Compressors AM1HE0205HD 2014 Power Cord Replacement, Power off the compressor: step 1, image 2 of 2
    • Before you begin, ensure the device is powered down and cool to the touch.
    • Ensure the compressor is unplugged.
    • Flip the pressure switch lever up to the off position.
  2. MiTM Air Compressors AM1HE0205HD 2014 Power Cord Replacement, Drain the air from the compressor: step 2, image 1 of 2 MiTM Air Compressors AM1HE0205HD 2014 Power Cord Replacement, Drain the air from the compressor: step 2, image 2 of 2
    • Pull the ring on the safety release valve away from the compressor tank to drain the air from the compressor.
    • Ensure all air is drained from the tank before beginning repairs.
  3. MiTM Air Compressors AM1HE0205HD 2014 Power Cord Replacement, Remove the pressure switch cover: step 3, image 1 of 1
    • Use a 5/16 inch socket to unscrew the bolt securing the pressure switch cover.
    • This is a captive bolt and will stay attached to the cover after you unscrew it.
  4. MiTM Air Compressors AM1HE0205HD 2014 Power Cord Replacement: step 4, image 1 of 2 MiTM Air Compressors AM1HE0205HD 2014 Power Cord Replacement: step 4, image 2 of 2
    • Remove the pressure switch cover.
  5. MiTM Air Compressors AM1HE0205HD 2014 Power Cord Replacement, Disconnect the power cord: step 5, image 1 of 2 MiTM Air Compressors AM1HE0205HD 2014 Power Cord Replacement, Disconnect the power cord: step 5, image 2 of 2
    • Use a Phillips driver to loosen the three screws securing the power cord wires.
  6. MiTM Air Compressors AM1HE0205HD 2014 Power Cord Replacement: step 6, image 1 of 2 MiTM Air Compressors AM1HE0205HD 2014 Power Cord Replacement: step 6, image 2 of 2
    • Slide the white power wire's spade terminal connector straight out from under its screw.
  7. MiTM Air Compressors AM1HE0205HD 2014 Power Cord Replacement: step 7, image 1 of 2 MiTM Air Compressors AM1HE0205HD 2014 Power Cord Replacement: step 7, image 2 of 2
    • Slide the black power wire's spade terminal connector straight out from under its screw.
    • Slide the green ground wire's spade terminal connector straight out from under its screw.
  8. MiTM Air Compressors AM1HE0205HD 2014 Power Cord Replacement, Remove the power cord: step 8, image 1 of 3 MiTM Air Compressors AM1HE0205HD 2014 Power Cord Replacement, Remove the power cord: step 8, image 2 of 3 MiTM Air Compressors AM1HE0205HD 2014 Power Cord Replacement, Remove the power cord: step 8, image 3 of 3
    • Use a pair of needle-nose pliers to squeeze the locking tab on the power cord bushing inwards, toward the cord.
    • While squeezing the locking tab, slide the bushing out of its hole in the pressure switch.
  9. MiTM Air Compressors AM1HE0205HD 2014 Power Cord Replacement: step 9, image 1 of 1
    • Remove the power cord.
  10. MiTM Air Compressors AM1HE0205HD 2014 Power Cord Replacement, Transfer the power cord bushing: step 10, image 1 of 1
    • If a new power cord bushing isn't included, make sure to transfer the old bushing to the new power cord.
  11. MiTM Air Compressors AM1HE0205HD 2014 Power Cord Replacement, Install new terminal connectors: step 11, image 1 of 2 MiTM Air Compressors AM1HE0205HD 2014 Power Cord Replacement, Install new terminal connectors: step 11, image 2 of 2
    • If the new power cord does not come with spade terminal connectors preinstalled, follow this step and the next to install new ones.
    • Slide a blue spade connector onto the stripped end of one of the power cord wires.
  12. MiTM Air Compressors AM1HE0205HD 2014 Power Cord Replacement: step 12, image 1 of 2 MiTM Air Compressors AM1HE0205HD 2014 Power Cord Replacement: step 12, image 2 of 2
    • Use a wire crimper at the 14 gauge (or blue) setting to crimp the spade terminal connector.
Adam O'Camb
199,443 Reputation
416 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 2
All Time: 209
