MiTM Pressure Washers CA2703HDHB1 2017 Recoil Starter Replacement
  1. MiTM Pressure Washers CA2703HDHB1 2017 Recoil Starter Replacement, Remove the recoil starter bolts: step 1, image 1 of 1
    • Before you begin, be sure that the engine is powered off and is cool to the touch.
    • Use a 10 mm socket to remove the three 24 mm long bolts.
  2. MiTM Pressure Washers CA2703HDHB1 2017 Recoil Starter Replacement, Remove the recoil starter assembly: step 2, image 1 of 1
    • Remove the recoil starter assembly.
  3. MiTM Pressure Washers CA2703HDHB1 2017 Recoil Starter Replacement: step 3, image 1 of 2 MiTM Pressure Washers CA2703HDHB1 2017 Recoil Starter Replacement: step 3, image 2 of 2
    • If you are replacing the assembly with a non-OEM part, you may also have to replace the starter cap.
    • Remove the 3/4" bolt with a deep socket.
    • This bolt can be very difficult to remove. Use the hook as a bracing point to keep the starter cap from rotating.
Arthur Shi
257,501 Reputation
529 Guides authored
iFixit Member of iFixit
Staff
141 Members
17,895 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 24
All Time: 739
