Miadore Classic N64 Controller Buttons Replacement
  1. Miadore Classic N64 Controller Buttons Replacement, Joystick: step 1, image 1 of 3 Miadore Classic N64 Controller Buttons Replacement, Joystick: step 1, image 2 of 3 Miadore Classic N64 Controller Buttons Replacement, Joystick: step 1, image 3 of 3
    • Use a Phillips #000 screwdriver to remove all nine 3.2 mm screws from the back of the controller.
    • Place the end of a spudger in the seam between the top and bottom of the controller to release the clips holding them together.
    • Separate the top and bottom cover of the controller.
  2. Miadore Classic N64 Controller Buttons Replacement: step 2, image 1 of 2 Miadore Classic N64 Controller Buttons Replacement: step 2, image 2 of 2
    • Remove the three 3.2 mm Phillips #000 screws holding the motherboard in place.
    • The motherboard will still be in place after the screws are removed.
  3. Miadore Classic N64 Controller Buttons Replacement: step 3, image 1 of 3 Miadore Classic N64 Controller Buttons Replacement: step 3, image 2 of 3 Miadore Classic N64 Controller Buttons Replacement: step 3, image 3 of 3
    • Remove the three 3.2 mm Phillips #000 screws holding the joystick module in place.
    • Remove the joystick module.
  4. Miadore Classic N64 Controller Buttons Replacement: step 4, image 1 of 2 Miadore Classic N64 Controller Buttons Replacement: step 4, image 2 of 2
    • Remove the joystick by pulling it away from the plastic needle-like object holding it in place.
    • Replace it with a new or custom joystick.
  5. Miadore Classic N64 Controller Buttons Replacement, Buttons: step 5, image 1 of 3 Miadore Classic N64 Controller Buttons Replacement, Buttons: step 5, image 2 of 3 Miadore Classic N64 Controller Buttons Replacement, Buttons: step 5, image 3 of 3
    • Remove the right and left bumper.
    • If the bumper buttons are the buttons that need to be replaced, you can stop here.
  6. Miadore Classic N64 Controller Buttons Replacement: step 6, image 1 of 3 Miadore Classic N64 Controller Buttons Replacement: step 6, image 2 of 3 Miadore Classic N64 Controller Buttons Replacement: step 6, image 3 of 3
    • Pull the motherboard up with even pressure on all sides.
    • Set the motherboard to the side.
  7. Miadore Classic N64 Controller Buttons Replacement: step 7, image 1 of 3 Miadore Classic N64 Controller Buttons Replacement: step 7, image 2 of 3 Miadore Classic N64 Controller Buttons Replacement: step 7, image 3 of 3
    • Remove the rubber gaskets.
    • This will reveal the buttons underneath.
  8. Miadore Classic N64 Controller Buttons Replacement: step 8, image 1 of 2 Miadore Classic N64 Controller Buttons Replacement: step 8, image 2 of 2
    • Push up from the bottom of the controller to pop the buttons out.
2 other people completed this guide.
angel villagomez
301 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 10
All Time: 249
