Micro-USB Port Replacement
  1. Micro-USB Port Replacement, Back Plate: step 1, image 1 of 2 Micro-USB Port Replacement, Back Plate: step 1, image 2 of 2
    • Unscrew the four 3.4 mm flat head screws
  2. Micro-USB Port Replacement: step 2, image 1 of 1
    • Carefully lift the back plate off the watch. You will notice a lithium battery and rubber gasket attached to the back plate.
  3. Micro-USB Port Replacement, Lithium Battery: step 3, image 1 of 1
    • If not replacing lithium battery, skip down two steps.
    • Using the plastic removal tool, pry the battery from the backing plate. The battery is simply attached with glue.
  4. Micro-USB Port Replacement: step 4, image 1 of 1
    • Desolder the battery connections from the motherboard. Learn how to solder components here!
  5. Micro-USB Port Replacement, Motherboard: step 5, image 1 of 1
    • Use PH00 screw driver to remove two 2.4mm Phillips head screws.
  6. Micro-USB Port Replacement: step 6, image 1 of 1
    Tool used on this step:
    Buy
    • Use a spudger or tweezers to remove a white sticker that covers a Phillips head screw.
  7. Micro-USB Port Replacement: step 7, image 1 of 1
    • Use PH00 screwdriver to remove 5.2mm Phillips head screw
  8. Micro-USB Port Replacement: step 8, image 1 of 3 Micro-USB Port Replacement: step 8, image 2 of 3 Micro-USB Port Replacement: step 8, image 3 of 3
    • Use ESD safe tweezers to remove the gold ribbon cable.
    • This will expose a second 5.2mm Phillips head screw that can be removed with a PH00 screwdriver.
  9. Micro-USB Port Replacement: step 9, image 1 of 2 Micro-USB Port Replacement: step 9, image 2 of 2
    • Use a spudger to gently pry on the motherboard towards the top of the watch, being towards the 12 o'clock position to loosen the motherboard.
    • You can now access the parts and pieces on the bottom of, and below the motherboard.
  10. Micro-USB Port Replacement, Micro-USB Port: step 10, image 1 of 1
    • Locate the four main soldering points marked in red.
    • Be aware of the five additional soldered pins marked by the blue arrow.
  11. Micro-USB Port Replacement: step 11, image 1 of 3 Micro-USB Port Replacement: step 11, image 2 of 3 Micro-USB Port Replacement: step 11, image 3 of 3
    • Begin to desolder the points pointed out in the last step.
    • Use the soldering wick to help remove the solder.
3 other people completed this guide.
Michael Miller
281 Reputation
2 Guides authored
IUPUI, Team 3-3, Baechle Fall 2016 Member of IUPUI, Team 3-3, Baechle Fall 2016
IUPUI-BAECHLE-F16S3G3
4 Members
8 Guides authored
1 Guide Comment
I want to know that what I have to do if want to replace the lithium battery with usb direct powered device.
amupis232389 - Reply
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 44
All Time: 17,723
