Microsoft Band 2 Battery Replacement
  1. Microsoft Band 2 Battery Replacement, Battery: step 1, image 1 of 1
    • Peel back the metal cover on the end of the watchband.
  2. Microsoft Band 2 Battery Replacement: step 2, image 1 of 1
    • Use a T3 Torx screwdriver to unscrew the four 6 mm screws on the corners of the metal cover plate.
  3. Microsoft Band 2 Battery Replacement: step 3, image 1 of 1
    • Use the plastic opening tool to pry off the metal cover plate.
  4. Microsoft Band 2 Battery Replacement: step 4, image 1 of 2 Microsoft Band 2 Battery Replacement: step 4, image 2 of 2
    Tool used on this step:
    Buy
    • Detach the black ribbon cable by using the tweezers.
  5. Microsoft Band 2 Battery Replacement: step 5, image 1 of 2 Microsoft Band 2 Battery Replacement: step 5, image 2 of 2
    • Detach the orange press-fit (or "pop") connector by using the tweezers.
  6. Microsoft Band 2 Battery Replacement: step 6, image 1 of 2 Microsoft Band 2 Battery Replacement: step 6, image 2 of 2
    • Pry out the battery using the plastic opening tool.
20 other people completed this guide.
Chris Syracuse
639 Reputation
3 Guides authored
USF Tampa, Team S1-G5, Leahy Spring 2017 Member of USF Tampa, Team S1-G5, Leahy Spring 2017
USFT-LEAHY-S17S1G5
3 Members
5 Guides authored
14 Guide Comments
My Band 2 is not charging and it showing empty battery with AC plugin Icon, but after longtime its not charging . In this case if I replace the battery is it will work or not?
Notes: did not turn on.
Tanvir Ahmed Howlader - Reply
Microsoft band guide works well - I managed to remove the battery easily - but where do I get a new battery from ?
Margo Bowes - Reply
TWO WORDS:
THANK YOU!
(A++++)
Somebody know where to buy battery replacement?
I Want Fix IT - Reply
The only place i found was ebay:
ftlay - Reply
Batteries can be found on ebay. I was surprised to see the band come back to life. I found the “pop” connector difficult to align properly. Almost lost patience with it. Got it on, reassembled and it powered up.
Dwight Gaut - Reply
Past 24 Hours: 6
Past 7 Days: 48
Past 30 Days: 121
All Time: 13,635
