Microsoft Band Wrist Clasp Replacement
  1. Microsoft Band Wrist Clasp Replacement, Wrist Clasp: step 1, image 1 of 1
    • Using the T3 Torx Screwdriver, remove the two 2.00mm long screws from the inside of the clasp.
  2. Microsoft Band Wrist Clasp Replacement: step 2, image 1 of 1
    • Remove the metal plate with the serial and model number on it by pulling it straight up around the two hooks.
  3. Microsoft Band Wrist Clasp Replacement: step 3, image 1 of 1
    • Pull the two securing pins out of the rubberized part of the band.
Chad Steese
256 Reputation
2 Guides authored
Cal Poly, Team 17-34, Amido Winter 2015 Member of Cal Poly, Team 17-34, Amido Winter 2015
CPSU-AMIDO-W15S17G34
4 Members
6 Guides authored
3 Comments
where can I purchase the replacement part
jeepgirlutah - Reply
+1 for Jeepgirlutah
Guide is not for replacing clasp, it just is for removing it... It has no use to remove the clasp while it is still properly attached.
The real question is on how to replace it when it is broken (like ripped off like mine did).
dopplerdefekt - Reply
I am a broken the strap where it holds the small piece of metal. I need a new belt spare? thanks and regards
Xavier Ribas Roig - Reply
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 8
All Time: 5,162
