Microsoft Lumia 535 Logic board Replacement
Video Overview
  1. Microsoft Lumia 535 Logic board Replacement, Back Cover / Rear Case: step 1, image 1 of 2 Microsoft Lumia 535 Logic board Replacement, Back Cover / Rear Case: step 1, image 2 of 2
    • Turn off the phone.
    • Remove the battery and any SIM and memory cards.
  2. Microsoft Lumia 535 Logic board Replacement: step 2, image 1 of 2 Microsoft Lumia 535 Logic board Replacement: step 2, image 2 of 2
    • With a screwdriver Torx T4 remove the 9x screws.
  3. Microsoft Lumia 535 Logic board Replacement: step 3, image 1 of 3 Microsoft Lumia 535 Logic board Replacement: step 3, image 2 of 3 Microsoft Lumia 535 Logic board Replacement: step 3, image 3 of 3
    • With a plastic opening tool separate the back cover from the middle frame.
  4. Microsoft Lumia 535 Logic board Replacement, Logic board: step 4, image 1 of 3 Microsoft Lumia 535 Logic board Replacement, Logic board: step 4, image 2 of 3 Microsoft Lumia 535 Logic board Replacement, Logic board: step 4, image 3 of 3
    • Disconnect:
    • Touch screen flex cable
    • LCD Display flex cable
    • Charging Dock board flex cable - remove the foam and tape, then flip up the black lock before easing out the flex.
    • Coaxial antena cable - take your time here, be sure to pull the metal connector and not the cable or you risk pulling the cable from the connector.
    • Remove the 2x Torx T4 screws.
  5. Microsoft Lumia 535 Logic board Replacement: step 5, image 1 of 3 Microsoft Lumia 535 Logic board Replacement: step 5, image 2 of 3 Microsoft Lumia 535 Logic board Replacement: step 5, image 3 of 3
    • Insert wisdom here.
8 other people completed this guide.
ZFix
192,056 Reputation
330 Guides authored
Master Techs Member of Master Techs
Community
321 Members
1,525 Guides authored
4 Comments
How can I add additional sensors- the gyroscope & compass chips on this logic board?
Abinash Pal - Reply
microsoft lumia 535 chargeing ic complete
Sunitha Kunapareddi - Reply
my Microsoft lumia 535 chargeing ic complient main mother board lo problem
My microsoft mobile 1090 is not displaying apps but on backlight
Please what can I do to it?
aribasoyeifeoluwa - Reply
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 5
All Time: 5,957
