Microsoft Lumia 535 Touch Screen Glass, LCD Display Replacement
Video Overview
  1. Microsoft Lumia 535 Touch Screen Glass, LCD Display Replacement, Back Cover / Rear Case: step 1, image 1 of 2 Microsoft Lumia 535 Touch Screen Glass, LCD Display Replacement, Back Cover / Rear Case: step 1, image 2 of 2
    • Turn off the phone.
    • Remove the battery and any SIM and memory cards.
  2. Microsoft Lumia 535 Touch Screen Glass, LCD Display Replacement: step 2, image 1 of 2 Microsoft Lumia 535 Touch Screen Glass, LCD Display Replacement: step 2, image 2 of 2
    • With a screwdriver Torx T4 remove the 9x screws.
  3. Microsoft Lumia 535 Touch Screen Glass, LCD Display Replacement: step 3, image 1 of 3 Microsoft Lumia 535 Touch Screen Glass, LCD Display Replacement: step 3, image 2 of 3 Microsoft Lumia 535 Touch Screen Glass, LCD Display Replacement: step 3, image 3 of 3
    • With a plastic opening tool separate the back cover from the middle frame.
  4. Microsoft Lumia 535 Touch Screen Glass, LCD Display Replacement, Logic board: step 4, image 1 of 3 Microsoft Lumia 535 Touch Screen Glass, LCD Display Replacement, Logic board: step 4, image 2 of 3 Microsoft Lumia 535 Touch Screen Glass, LCD Display Replacement, Logic board: step 4, image 3 of 3
    • Disconnect:
    • Touch screen flex cable
    • LCD Display flex cable
    • Charging Dock board flex cable - remove the foam and tape, then flip up the black lock before easing out the flex.
    • Coaxial antena cable - take your time here, be sure to pull the metal connector and not the cable or you risk pulling the cable from the connector.
    • Remove the 2x Torx T4 screws.
  5. Microsoft Lumia 535 Touch Screen Glass, LCD Display Replacement: step 5, image 1 of 3 Microsoft Lumia 535 Touch Screen Glass, LCD Display Replacement: step 5, image 2 of 3 Microsoft Lumia 535 Touch Screen Glass, LCD Display Replacement: step 5, image 3 of 3
    • Insert wisdom here.
  6. Microsoft Lumia 535 Touch Screen Glass, LCD Display Replacement, Touch Screen Glass, LCD Display: step 6, image 1 of 3 Microsoft Lumia 535 Touch Screen Glass, LCD Display Replacement, Touch Screen Glass, LCD Display: step 6, image 2 of 3 Microsoft Lumia 535 Touch Screen Glass, LCD Display Replacement, Touch Screen Glass, LCD Display: step 6, image 3 of 3
    • Remove the display flex cable rubber.
    • Put scotch tape on glass to prevent it from shattering.
    • Use a hair dryer or heat gun and warm the glass to make adhesive soft.
  7. Microsoft Lumia 535 Touch Screen Glass, LCD Display Replacement: step 7, image 1 of 3 Microsoft Lumia 535 Touch Screen Glass, LCD Display Replacement: step 7, image 2 of 3 Microsoft Lumia 535 Touch Screen Glass, LCD Display Replacement: step 7, image 3 of 3
    • Use a cutter or other tool with a sharp edge and start the separating from the bottom side. When you make enough room, continue the operation with a plastic tool.
    • Work slowly and do not force the frame with the display too much.
    • If necessary, warm again the glass with a hairdryer.
  8. Microsoft Lumia 535 Touch Screen Glass, LCD Display Replacement: step 8, image 1 of 3 Microsoft Lumia 535 Touch Screen Glass, LCD Display Replacement: step 8, image 2 of 3 Microsoft Lumia 535 Touch Screen Glass, LCD Display Replacement: step 8, image 3 of 3
    • Using a plastic tool, carefully remove the display.
    • Clean the frame from the remainders of the old adhesive.
  9. Microsoft Lumia 535 Touch Screen Glass, LCD Display Replacement: step 9, image 1 of 3 Microsoft Lumia 535 Touch Screen Glass, LCD Display Replacement: step 9, image 2 of 3 Microsoft Lumia 535 Touch Screen Glass, LCD Display Replacement: step 9, image 3 of 3
    • Install back the display.
    • Put adhesive tape 2mm on the digitizer.
    • Order the digitizer glass together with an adhesive tape. The replacement is easier.
  10. Microsoft Lumia 535 Touch Screen Glass, LCD Display Replacement: step 10, image 1 of 2 Microsoft Lumia 535 Touch Screen Glass, LCD Display Replacement: step 10, image 2 of 2
    • Install the touch screen and start with the reassembling.
    • That's all.
    • Did you do it successfully?
50 other people completed this guide.
ZFix
191,882 Reputation
330 Guides authored
Master Techs Member of Master Techs
Community
321 Members
1,516 Guides authored
19 Comments
hi
cane you tell me price of out glass of lumia 535 duol sim please ?!
omarkhalil - Reply
2mm adhesive tape means thickness
Jithu - Reply
Also does touch come out if we put adhesive tape.
Jithu - Reply
I want to join in your team
Saikrishna - Reply
Hi,How to know which the versions touch screens my phone is Lumia 535 RM-1089 , please?
priscilaalmerinda - Reply
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 35
All Time: 111,514
