Microsoft Lumia 640 XL Touch Screen Replacement
  1. Microsoft Lumia 640 XL Touch Screen Replacement, Battery: step 1, image 1 of 3 Microsoft Lumia 640 XL Touch Screen Replacement, Battery: step 1, image 2 of 3 Microsoft Lumia 640 XL Touch Screen Replacement, Battery: step 1, image 3 of 3
    • Place left palm on screen and right palm on the back.
    • Press down with fingertips and pull to separate the back from the screen.
    • You may hear cracking and popping.
  2. Microsoft Lumia 640 XL Touch Screen Replacement: step 2, image 1 of 2 Microsoft Lumia 640 XL Touch Screen Replacement: step 2, image 2 of 2
    • Lift the battery away from the phone with the flat side of a spudger.
    • Be careful not to damage the battery.
  3. Microsoft Lumia 640 XL Touch Screen Replacement, Headphone Jack: step 3, image 1 of 3 Microsoft Lumia 640 XL Touch Screen Replacement, Headphone Jack: step 3, image 2 of 3 Microsoft Lumia 640 XL Touch Screen Replacement, Headphone Jack: step 3, image 3 of 3
    • Remove all ten T3, 4.09 mm screws.
    • Lift mid-frame assembly from phone with flat side of a spudger.
  4. Microsoft Lumia 640 XL Touch Screen Replacement: step 4, image 1 of 3 Microsoft Lumia 640 XL Touch Screen Replacement: step 4, image 2 of 3 Microsoft Lumia 640 XL Touch Screen Replacement: step 4, image 3 of 3
    Tool used on this step:
    Buy
    • Lift and peel connector away from phone using tweezers.
    • To re-attach you may need E6000 Adhesive Glue.
  5. Microsoft Lumia 640 XL Touch Screen Replacement, Motherboard: step 5, image 1 of 2 Microsoft Lumia 640 XL Touch Screen Replacement, Motherboard: step 5, image 2 of 2
    • Remove all three T3, 2.66 mm screws.
  6. Microsoft Lumia 640 XL Touch Screen Replacement: step 6, image 1 of 3 Microsoft Lumia 640 XL Touch Screen Replacement: step 6, image 2 of 3 Microsoft Lumia 640 XL Touch Screen Replacement: step 6, image 3 of 3
    Buy
    • Lift off connector with tweezers.
    • Lift motherboard off with tweezers and pull away with fingers.
  7. Microsoft Lumia 640 XL Touch Screen Replacement, Touch Screen: step 7, image 1 of 2 Microsoft Lumia 640 XL Touch Screen Replacement, Touch Screen: step 7, image 2 of 2
    • Remove the screen from the device.
    • Touch screen digitizer and screen glass are one unit.
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 11
All Time: 1,239
