Microsoft Lumia 950 XL Screen Replacement
  1. Microsoft Lumia 950 XL Screen Replacement, Removing back cover & battery: step 1, image 1 of 3 Microsoft Lumia 950 XL Screen Replacement, Removing back cover & battery: step 1, image 2 of 3 Microsoft Lumia 950 XL Screen Replacement, Removing back cover & battery: step 1, image 3 of 3
    • The Lumia 950 XL back cover is super easy to remove. There is a dent at the bottom of the phone to guide you to where you should start working.
    • Crack the back cover open using your fingers.
    • Lift the battery out using your fingers.
    • Everything should pop out easily since there is no glue or adhesive to worry about.
    • Make sure to remove the SIM card or microSD card if they are inserted.
  2. Microsoft Lumia 950 XL Screen Replacement, Removing back panel: step 2, image 1 of 3 Microsoft Lumia 950 XL Screen Replacement, Removing back panel: step 2, image 2 of 3 Microsoft Lumia 950 XL Screen Replacement, Removing back panel: step 2, image 3 of 3
    • Unscrew the 12 Torx screws (T5) in the back panel.
    • Lift the back plate from the bottom of the phone.
    • To remove this back panel, there is a clasp hidden beneath the round camera cut out. Use a tweezer to gently remove it. No force is required.
  3. Microsoft Lumia 950 XL Screen Replacement, Removing headphone jack: step 3, image 1 of 3 Microsoft Lumia 950 XL Screen Replacement, Removing headphone jack: step 3, image 2 of 3 Microsoft Lumia 950 XL Screen Replacement, Removing headphone jack: step 3, image 3 of 3
    • Now that the back plate is off, it shows various interesting components like the heat pipe, earpiece & loud speaker.
    • Remove the headphone jack connector using a spudger. Then lift using a tweezer.
  4. Microsoft Lumia 950 XL Screen Replacement, Disconnect connectors: step 4, image 1 of 3 Microsoft Lumia 950 XL Screen Replacement, Disconnect connectors: step 4, image 2 of 3 Microsoft Lumia 950 XL Screen Replacement, Disconnect connectors: step 4, image 3 of 3
    • There are three connectors that need to be disconnected before working with the motherboard.
    • With a spudger, remove the first two connectors.
    • Another small connector is connected with the side buttons. Again, disconnect them using a spudger.
  5. Microsoft Lumia 950 XL Screen Replacement, Removing motherboard: step 5, image 1 of 3 Microsoft Lumia 950 XL Screen Replacement, Removing motherboard: step 5, image 2 of 3 Microsoft Lumia 950 XL Screen Replacement, Removing motherboard: step 5, image 3 of 3
    Tool used on this step:
    Buy
    • The motherboard is clipped with the back of the display panel.
    • Start working with the top right of the phone. Remove the motherboard from the clip by hand or use a Jimmy to leverage in little force to make it easier.
    • Use tweezers to lift the motherboard up. This may require a little force since this part of the board has little clips underneath.
    • Continue working with the motherboard all the way around till the bottom half of the phone. Straightforward!
  6. Microsoft Lumia 950 XL Screen Replacement, Disconnect last connector to remove motherboard: step 6, image 1 of 3 Microsoft Lumia 950 XL Screen Replacement, Disconnect last connector to remove motherboard: step 6, image 2 of 3 Microsoft Lumia 950 XL Screen Replacement, Disconnect last connector to remove motherboard: step 6, image 3 of 3
    • One last connector needs to be disconnected on the back of the motherboard.
    • Start by peeling of the sticker beneath the battery.
    • Lift the motherboard up, starting from the bottom of the phone, and flip it gently. You will see the hidden connector.
    • This connector also connect the motherboard to the daughter board.
    • Disconnect it with a spudger
    • Now the motherboard can be removed.
  7. Microsoft Lumia 950 XL Screen Replacement, Removing the daughter board: step 7, image 1 of 3 Microsoft Lumia 950 XL Screen Replacement, Removing the daughter board: step 7, image 2 of 3 Microsoft Lumia 950 XL Screen Replacement, Removing the daughter board: step 7, image 3 of 3
    • Remove the two connectors that connect the daughter board with the motherboard. They are lightly adhered in place and can be peeled off easily by hand.
    • Remove the daughter board by using a spudger.
  8. Microsoft Lumia 950 XL Screen Replacement, Harvest vibrating motor & side panel: step 8, image 1 of 3 Microsoft Lumia 950 XL Screen Replacement, Harvest vibrating motor & side panel: step 8, image 2 of 3 Microsoft Lumia 950 XL Screen Replacement, Harvest vibrating motor & side panel: step 8, image 3 of 3
    • Remove the vibrating motor using a spudger.
    • Remove the side panel with a spudger. It is lightly adhered but can be lifted by fingers or a tweezer.
  9. Microsoft Lumia 950 XL Screen Replacement, Insert components into new screen: step 9, image 1 of 2 Microsoft Lumia 950 XL Screen Replacement, Insert components into new screen: step 9, image 2 of 2
    • Start the assembly process by placing the daughter board into the new screen
    • Place the vibrating motor back into its place.
    • The new screen should come with a light adhesive to hold the two cables from the daughterboard.
  10. Microsoft Lumia 950 XL Screen Replacement, Reassembly the motherboard: step 10, image 1 of 3 Microsoft Lumia 950 XL Screen Replacement, Reassembly the motherboard: step 10, image 2 of 3 Microsoft Lumia 950 XL Screen Replacement, Reassembly the motherboard: step 10, image 3 of 3
    • Reconnect a connector on the back of the motherboard, clipping the board in place. Start with the top right corner of the phone and push the motherboard into the clips using a spudger.
    • Reconnect all 3 connectors.
  11. Microsoft Lumia 950 XL Screen Replacement, The return of the headphone Jack!!: step 11, image 1 of 1
    • Place the headphone jack and connect it to the motherboard.
    • Reapply the sticker beneath the battery
    • Well, this can be done later after trying to turn on the device.
    • Place the back panel on top of the motherboard, and screw in all 12 screws!
  12. Microsoft Lumia 950 XL Screen Replacement, And we are done!!: step 12, image 1 of 1
    • After closing of the back cover, try turning the phone on!!
    • This replacement part is an OLED screen. It is much higher quality compared with the LCD replacement screen.
Thank you for following us. This is a complete disassembly - replacement - reassembly guide. So, your phone should be working normally again!
6 other people completed this guide.
Anan Venasakulchai
837 Reputation
2 Guides authored
Finn Store Member of Finn Store
Business
1 Member
5 Guides authored
0 Comments
Past 24 Hours: 5
Past 7 Days: 14
Past 30 Days: 61
All Time: 3,049
