Introduction
Replacing the kickstand is one of the simplest things to fix in a Surface 3. However, you will still need to take off the display and remove the battery to fully access the parts to replace.
Warm up an iOpener following the instructions found in the iOpener guide.
Place the warm iOpener on top of the edges of the screen. This heat will weaken the strength of the adhesive between the display and body.
Now that you've gotten the casing off of the Surface 3, you can start removing the battery pack.
Tool used on this step:Plastic Cards$2.99
Slide the iFixit plastic cards under the compartments of the battery pack.
Slide the card around to undo the adhesive under the battery pack
4 other people completed this guide.
2 Guide Comments
Please can you tell me which kickstand the surface pro 3 64 GB (2013) needs? Is it the same as the surface pro 4 ? I have broken the stand and am trying yo source a replacement.
