Microsoft Surface Book 2 15" Dock Port Connector Replacement
  1. Microsoft Surface Book 2 15" Dock Port Connector Replacement, Remove Back Plate: step 1, image 1 of 3 Microsoft Surface Book 2 15" Dock Port Connector Replacement, Remove Back Plate: step 1, image 2 of 3 Microsoft Surface Book 2 15" Dock Port Connector Replacement, Remove Back Plate: step 1, image 3 of 3
    • Detach screen first, and set aside. Using the hair dryer heat up the side you're going to start with. Remember to move the hair dryer up and down the side. Don't let it heat one spot for too long.
    • Using the Razer Scraper, you can heat the tool up if you'd like, put in the crevice between the back plate and the edge.
    • Gently pry the back plate up.
    • TIP: Having isopropyl alcohol and a toothbrush may come in handy. Dip toothbrush into the alcohol, don't let it be dripping wet, and scrub the edges you're working on to help dry the glue.
    • Once you have an opening put one of the open picks in point side first and using the hair dryer heating the edge and slowly slide and turn the opening pick so that the large part is in and the point is out.
    • At this point you can sacrifice one of your open picks, and use it to slowly work your way through the glue, remember to heat the edges as you work your way along the edge. When you get to a corner be sure to leave a an open pick there. You may need to use the Razer Scraper but just be careful so you don't leave scratches.
    • When you get to the touch pad there may be glue perpendicular to the edge underneath so be careful. I highly suggest using the open picks as they're plastic, or a credit card.
    • TIP: Take your time and don't force it. Use your hair dryer to your advantage. You will get it eventually. I used the Razer Scraper to get my first 2 open picks in and then for the most part used an open pick and alcohol to cut through the glue.
  2. Microsoft Surface Book 2 15" Dock Port Connector Replacement, Open & Detach Cables: step 2, image 1 of 2 Microsoft Surface Book 2 15" Dock Port Connector Replacement, Open & Detach Cables: step 2, image 2 of 2
    • Open it slowly with the "binding" to the touch pad to avoid issues with the ribbon cable
    • You should be able to gently bring the touch pad in so that you can lay the back plate flat and remove the two connectors connecting to the touch pad.
    • Begin by removing ribbon cables but be careful and use plastic tools if you need help.
    • TIP: Review the Video to understand how to remove the cables. It was tough getting them out but working it slowly I eventually got them all free.
    • Unlock the Dock Cable from GPU board, Next step has a video of removing the cables.
    • Remove Dock Cable from GPU Board
  3. Microsoft Surface Book 2 15" Dock Port Connector Replacement, Remove Screws: step 6, image 1 of 3 Microsoft Surface Book 2 15" Dock Port Connector Replacement, Remove Screws: step 6, image 2 of 3 Microsoft Surface Book 2 15" Dock Port Connector Replacement, Remove Screws: step 6, image 3 of 3
    • There are two boards in here, the USB and SD Card reader board (Pink), then the GPU, USB C, and charging board (Blue). There is also a plastic protector, I believe for stability (Green).
    • Remove all the screws From the Boards and plastic protector. (Torx T3)
    • Be sure to pop off the connector to the second board, as there is a screw hiding beneath it.
  4. Microsoft Surface Book 2 15" Dock Port Connector Replacement, Remove USB/SD Card Reader: step 7, image 1 of 2 Microsoft Surface Book 2 15" Dock Port Connector Replacement, Remove USB/SD Card Reader: step 7, image 2 of 2
    • This part is a little difficult since it's a tight fit you may want to get a piece of plastic to gently, DO NOT FORCE, push the usb port in while you pull the board out.
  5. Microsoft Surface Book 2 15" Dock Port Connector Replacement, Remove dGPU & Dock Cable: step 8, image 1 of 3 Microsoft Surface Book 2 15" Dock Port Connector Replacement, Remove dGPU & Dock Cable: step 8, image 2 of 3 Microsoft Surface Book 2 15" Dock Port Connector Replacement, Remove dGPU & Dock Cable: step 8, image 3 of 3
    • Ensure cables are disconnected, screws are out. The dGPU board should slide out pretty easily
    • You may be able to remove the dock cable without removing the hinge, however I removed the hinge by unscrewing the 3 black screws on each side, for a total of 6. (Torx TR8)
    • To remove the Dock cable you will need to remove the metal sticker with model information covering the screws holding the cable in place.
    • Remove the screws from the dock cable and it should be fairly easy to slide out. (Torx T4)
Now add in your new dock port connector, and reassemble your device following these instructions in reverse order.
TIP: Don't forget to clean the old tape residue up before applying new tape.
FangerZero
304 Reputation
2 Guides authored
3 Comments
This was most helpful! I got the connector cable for around 17€. Finally the base holds its connection and doesn't disconnect all the time. Take your time while opening as urged by the guide, the rest is fairly easy.
Felix Korff - Reply
Hi, where did you find the connector ? ... Could not find one without the full hinge assembly (much more expensive ...)
Thanks for your help :)
Nestor - Reply
Past 24 Hours: 1
Past 7 Days: 24
Past 30 Days: 85
All Time: 1,953
