Microsoft Surface Laptop 4 (13.5-inch) Left Speaker Replacement
  1. Microsoft Surface Laptop 4 (13.5-inch) Left Speaker Replacement, Prepare your laptop for disassembly: step 1, image 1 of 2 Microsoft Surface Laptop 4 (13.5-inch) Left Speaker Replacement, Prepare your laptop for disassembly: step 1, image 2 of 2
    • Allow your laptop's battery to drain below 25% before starting this repair. A charged battery may catch fire if damaged.
    • Unplug all cables and fully shut down your laptop.
  2. Microsoft Surface Laptop 4 (13.5-inch) Left Speaker Replacement, Flip the laptop over: step 2, image 1 of 2 Microsoft Surface Laptop 4 (13.5-inch) Left Speaker Replacement, Flip the laptop over: step 2, image 2 of 2
    • Close the screen and lay your laptop down with the rear case facing up to access the four rubber feet.
  3. Microsoft Surface Laptop 4 (13.5-inch) Left Speaker Replacement, Feet removal information: step 3, image 1 of 3 Microsoft Surface Laptop 4 (13.5-inch) Left Speaker Replacement, Feet removal information: step 3, image 2 of 3 Microsoft Surface Laptop 4 (13.5-inch) Left Speaker Replacement, Feet removal information: step 3, image 3 of 3
    • Each foot has a recess to help pry it from the laptop:
    • The back feet recesses are closest to the back edge of the laptop.
    • The front feet recesses are closest to the front edge of the laptop.
  4. Microsoft Surface Laptop 4 (13.5-inch) Left Speaker Replacement, Remove the feet: step 4, image 1 of 3 Microsoft Surface Laptop 4 (13.5-inch) Left Speaker Replacement, Remove the feet: step 4, image 2 of 3 Microsoft Surface Laptop 4 (13.5-inch) Left Speaker Replacement, Remove the feet: step 4, image 3 of 3
    Tool used on this step:
    Buy
    • Insert one arm of your tweezers into the recess of one of the feet.
    • Twist your tweezers and pry up to separate the adhesive and unclip the foot from the laptop.
    • The feet eject very quickly—be careful not to lose them.
    • Remove the foot.
    • Repeat this process on the remaining feet.
  5. Microsoft Surface Laptop 4 (13.5-inch) Left Speaker Replacement, Reassembly information: step 5, image 1 of 2 Microsoft Surface Laptop 4 (13.5-inch) Left Speaker Replacement, Reassembly information: step 5, image 2 of 2
    Tesa 61395 Tape
    $5.99
    Buy
    • This laptop has two different types of feet. During reassembly, make sure the feet go in their correct recesses.
    • The rear feet have a single center clip.
    • The front feet have three clips and can only be reinserted one way.
    • Press the feet into their recesses to secure them to the frame.
    • If the existing feet no longer adhere to the frame, remove the old adhesive and apply a small amount of Tesa Tape where the old adhesive was.
  6. Microsoft Surface Laptop 4 (13.5-inch) Left Speaker Replacement: step 6, image 1 of 3 Microsoft Surface Laptop 4 (13.5-inch) Left Speaker Replacement: step 6, image 2 of 3 Microsoft Surface Laptop 4 (13.5-inch) Left Speaker Replacement: step 6, image 3 of 3
    • If the feet are damaged or worn out, use 8 mm rubber furniture pads:
    • Peel a pad away from its backing.
    • Align the pad over a foot cavity and press down to secure it.
  7. Microsoft Surface Laptop 4 (13.5-inch) Left Speaker Replacement, Unfasten the upper case: step 7, image 1 of 1
    FixMat
    $36.95
    Buy
    • These screws strip easily. Apply constant, downward force to prevent stripping.
    • Use a T5 Torx driver to remove the four 3 mm screws securing the upper case.
  8. Microsoft Surface Laptop 4 (13.5-inch) Left Speaker Replacement, Open the screen: step 8, image 1 of 3 Microsoft Surface Laptop 4 (13.5-inch) Left Speaker Replacement, Open the screen: step 8, image 2 of 3 Microsoft Surface Laptop 4 (13.5-inch) Left Speaker Replacement, Open the screen: step 8, image 3 of 3
    • Flip your laptop over and fully open the screen.
  9. Microsoft Surface Laptop 4 (13.5-inch) Left Speaker Replacement, Lift the upper case: step 9, image 1 of 3 Microsoft Surface Laptop 4 (13.5-inch) Left Speaker Replacement, Lift the upper case: step 9, image 2 of 3 Microsoft Surface Laptop 4 (13.5-inch) Left Speaker Replacement, Lift the upper case: step 9, image 3 of 3
    • The upper case is secured by magnets.
    • Grip the top edge of the upper case above the keyboard and lift straight up to release it.
    • Don't try to completely remove the upper case, as it's still connected to the laptop by a cable.
    • Lift the bottom edge of the upper case up and away from the laptop, taking care to not strain the ribbon cable underneath.
    • During reassembly, lower the upper case onto the lower case until the magnets snap into place and it lays flat.
    • Check that the upper case sits flush around the entire perimeter. Any gaps between the upper and lower case near the screen could damage the screen as it closes.
  10. Microsoft Surface Laptop 4 (13.5-inch) Left Speaker Replacement, Disconnect the keyboard and touchpad cable: step 10, image 1 of 3 Microsoft Surface Laptop 4 (13.5-inch) Left Speaker Replacement, Disconnect the keyboard and touchpad cable: step 10, image 2 of 3 Microsoft Surface Laptop 4 (13.5-inch) Left Speaker Replacement, Disconnect the keyboard and touchpad cable: step 10, image 3 of 3
    • The keyboard and touchpad cable connects the upper case to the laptop.
    • Insert the pointed end of a spudger under one edge of the magnet connector and pry up to disconnect it.
    • To reconnect the cable, align the magnet connector over its socket with the cable facing the bottom of the laptop. Press down on the connector to secure it.
  11. Microsoft Surface Laptop 4 (13.5-inch) Left Speaker Replacement, Remove the upper case: step 11, image 1 of 1
    • Remove the upper case and set it keyboard-side down on a clean surface.
  12. Microsoft Surface Laptop 4 (13.5-inch) Left Speaker Replacement, Unfasten the SSD: step 12, image 1 of 1
    • Use a T5 Torx driver to remove the 2.7 mm screw securing the SSD.
    • With the screw removed, the SSD pops up at a shallow angle.
  13. Microsoft Surface Laptop 4 (13.5-inch) Left Speaker Replacement, Remove the SSD: step 13, image 1 of 2 Microsoft Surface Laptop 4 (13.5-inch) Left Speaker Replacement, Remove the SSD: step 13, image 2 of 2
    • Removing the SSD also functions as a battery disconnect.
    • Pull the SSD out of its socket and remove it.
    • Don't pull up at a sharp angle, as this could damage the SSD and its socket.
    • During reassembly, insert the SSD at a slight angle.
  14. Microsoft Surface Laptop 4 (13.5-inch) Left Speaker Replacement, Remove one heatsink screw: step 14, image 1 of 1
    • Use a T3 Torx driver to remove the 3 mm screw securing the left side of the heatsink, near the left speaker connector.
  15. Microsoft Surface Laptop 4 (13.5-inch) Left Speaker Replacement, Lift up the edge of the heatsink: step 15, image 1 of 2 Microsoft Surface Laptop 4 (13.5-inch) Left Speaker Replacement, Lift up the edge of the heatsink: step 15, image 2 of 2
    Buy
    • Use a pair of tweezers or your fingers to lift the left side of the heatsink where you just removed a screw.
  16. Microsoft Surface Laptop 4 (13.5-inch) Left Speaker Replacement, Disconnect the left speaker: step 16, image 1 of 3 Microsoft Surface Laptop 4 (13.5-inch) Left Speaker Replacement, Disconnect the left speaker: step 16, image 2 of 3 Microsoft Surface Laptop 4 (13.5-inch) Left Speaker Replacement, Disconnect the left speaker: step 16, image 3 of 3
    • While holding the heat sink up, use the pointed end of a spudger to lift and disconnect the left speaker wire from its connector on the motherboard.
    • Lower the heatsink back into place.
  17. Microsoft Surface Laptop 4 (13.5-inch) Left Speaker Replacement, Unfasten the speaker: step 17, image 1 of 1
    • Use a T3 Torx driver to remove the three 2.6 mm screws securing the left speaker.
  18. Microsoft Surface Laptop 4 (13.5-inch) Left Speaker Replacement, Remove the speaker: step 18, image 1 of 3 Microsoft Surface Laptop 4 (13.5-inch) Left Speaker Replacement, Remove the speaker: step 18, image 2 of 3 Microsoft Surface Laptop 4 (13.5-inch) Left Speaker Replacement, Remove the speaker: step 18, image 3 of 3
    • Lift and remove the left speaker from its three posts.
Clay Eickemeyer
70,402 Reputation
453 Guides authored
iFixit Member of iFixit
Staff
140 Members
18,058 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 9
All Time: 76
