Microsoft Surface Laptop 7 (13.8-inch) Lower Case Replacement
  1. Microsoft Surface Laptop 7 (13.8-inch) Lower Case Replacement, Prepare your laptop for disassembly: step 1, image 1 of 2 Microsoft Surface Laptop 7 (13.8-inch) Lower Case Replacement, Prepare your laptop for disassembly: step 1, image 2 of 2
    • Unplug all cables and fully shut down your laptop.
  2. Microsoft Surface Laptop 7 (13.8-inch) Lower Case Replacement, Flip your laptop over: step 2, image 1 of 3 Microsoft Surface Laptop 7 (13.8-inch) Lower Case Replacement, Flip your laptop over: step 2, image 2 of 3 Microsoft Surface Laptop 7 (13.8-inch) Lower Case Replacement, Flip your laptop over: step 2, image 3 of 3
    • Close your laptop and lay it down so the rubber feet are facing up.
  3. Microsoft Surface Laptop 7 (13.8-inch) Lower Case Replacement, Remove the feet: step 3, image 1 of 3 Microsoft Surface Laptop 7 (13.8-inch) Lower Case Replacement, Remove the feet: step 3, image 2 of 3 Microsoft Surface Laptop 7 (13.8-inch) Lower Case Replacement, Remove the feet: step 3, image 3 of 3
    • Gently slide one arm of your angled tweezers into the recess near the upper right edge of one of the feet.
    • You can also use the point of a spudger. However, you're more likely to damage the foot, if you're reusing it.
    • Use your tweezers to pry up and remove the foot.
    • The feet may eject very quickly—be careful not to lose them.
    • Repeat the process to remove the remaining feet.
    • To install a foot, align the pegs on the bottom with their cutouts in the frame and press the foot into place.
  4. Microsoft Surface Laptop 7 (13.8-inch) Lower Case Replacement, Remove the lower case screws: step 4, image 1 of 2 Microsoft Surface Laptop 7 (13.8-inch) Lower Case Replacement, Remove the lower case screws: step 4, image 2 of 2
    Tool used on this step:
    FixMat
    $36.95
    Buy
    • While the Surface Laptop 7 uses Torx Plus screws, standard Torx bits work. Make sure to apply constant, downward force to prevent stripping.
    • Use a Torx Plus 5IP screwdriver to remove the four 4.5 mm‑long screws (with washers) securing the lower case.
  5. Microsoft Surface Laptop 7 (13.8-inch) Lower Case Replacement, Detach the lower case: step 5, image 1 of 3 Microsoft Surface Laptop 7 (13.8-inch) Lower Case Replacement, Detach the lower case: step 5, image 2 of 3 Microsoft Surface Laptop 7 (13.8-inch) Lower Case Replacement, Detach the lower case: step 5, image 3 of 3
    • Insert the tip of an opening pick under the top edge of the lower case, about an inch (2.5 cm) to the left or right of the Microsoft logo.
    • Don't insert the pick near the outer edges or you'll damage the antenna bar.
  6. Microsoft Surface Laptop 7 (13.8-inch) Lower Case Replacement: step 6, image 1 of 3 Microsoft Surface Laptop 7 (13.8-inch) Lower Case Replacement: step 6, image 2 of 3 Microsoft Surface Laptop 7 (13.8-inch) Lower Case Replacement: step 6, image 3 of 3
    • Twist the pick to lift the lower case enough that you can grip it with your hand.
  7. Microsoft Surface Laptop 7 (13.8-inch) Lower Case Replacement, Remove the lower case: step 7, image 1 of 3 Microsoft Surface Laptop 7 (13.8-inch) Lower Case Replacement, Remove the lower case: step 7, image 2 of 3 Microsoft Surface Laptop 7 (13.8-inch) Lower Case Replacement, Remove the lower case: step 7, image 3 of 3
    • Lift the lower case and remove it.
Spencer Day
94,632 Reputation
662 Guides authored
iFixit Member of iFixit
Staff
118 Members
19,418 Guides authored
0 Comments
Past 24 Hours: 3
Past 7 Days: 19
Past 30 Days: 45
All Time: 302
