This version may contain incorrect edits. Switch to the latest verified snapshot.
Microsoft Surface Pro Charging Port Replacement
Introduction
Go to step 1Use this guide to replace the charging port in a Microsoft Surface Pro.
Use a heated iOpener or a heat gun to heat the edges of the display and soften its adhesive.
Apply a suction cup as close as possible to the edge of the display.
Use the suction cup to lift the edge of the display enough to insert an opening pick under the edge.
Slide the opening pick all the way around the edges of the display to cut through the adhesive on the bezel.
Ribbon cables and a circuit board are approx. 0.6 cm from the edge of the glass.
Starting from the top edge, lift the display slightly.
Before completely removing the display:
Disconnect the three display cables.
Gently peel from the frame 2 orange ribbon cables that are glued to it, as those should stay with the display. (e.g. use a thin plastic card to separate them)
5 other people completed this guide.
4 Guide Comments
Where do you get a replacement charging port at?
