Microsoft Zune 80 Case Replacement
  1. Microsoft Zune 80 Case Replacement, Case: step 1, image 1 of 1
    • Use a metal spudger or Zune opening tool to remove the small silver plastic cap on top of the device.
  2. Microsoft Zune 80 Case Replacement: step 2, image 1 of 1
    • There are two T3 screws under the cap. Remove both with a T3 screwdriver.
    • Be careful with removing these screws! These screwheads are prone to breaking.
  3. Microsoft Zune 80 Case Replacement, Remove the Casing: step 3, image 1 of 2 Microsoft Zune 80 Case Replacement, Remove the Casing: step 3, image 2 of 2
    • Using a metal spudger or Zune opening tool, remove the aluminum backing starting from the top. There are 5 clips on each side and two on the bottom.
    • Be careful not to press the tools in too far; there are exposed cables right inside the edge of the device.
turey
417 Reputation
2 Guides authored
Cal Poly, Team 6-5, Maness Fall 2009 Member of Cal Poly, Team 6-5, Maness Fall 2009
CPSU-MANESS-F09S6G5
5 Members
8 Guides authored
1 Guide Comment
I have followed these steps but im unable to get the back case off, any tips for a stubborn backing?
zippy9765 - Reply Share
Past 24 Hours: 1
Past 7 Days: 14
Past 30 Days: 86
All Time: 5,312
