Microtek ScanMaker 5900 New Locking Mechanism Replacement
  1. Microtek ScanMaker 5900 New Locking Mechanism Replacement, Remove serial port connection: step 1, image 1 of 3 Microtek ScanMaker 5900 New Locking Mechanism Replacement, Remove serial port connection: step 1, image 2 of 3 Microtek ScanMaker 5900 New Locking Mechanism Replacement, Remove serial port connection: step 1, image 3 of 3
    • Loosen the screws on the serial port by turning them counter clockwise by hand.
    • After loosening the screws, pull the serial port out.
  2. Microtek ScanMaker 5900 New Locking Mechanism Replacement, Remove Lid: step 2, image 1 of 3 Microtek ScanMaker 5900 New Locking Mechanism Replacement, Remove Lid: step 2, image 2 of 3 Microtek ScanMaker 5900 New Locking Mechanism Replacement, Remove Lid: step 2, image 3 of 3
    • Lift lid to its vertical position.
    • Pull lid straight up to remove it from the scanner.
  3. Microtek ScanMaker 5900 New Locking Mechanism Replacement, Detach plastic latches: step 3, image 1 of 3 Microtek ScanMaker 5900 New Locking Mechanism Replacement, Detach plastic latches: step 3, image 2 of 3 Microtek ScanMaker 5900 New Locking Mechanism Replacement, Detach plastic latches: step 3, image 3 of 3
    • Push the plastic opening tools into the crack between the top and the bottom of the chassis.
  4. Microtek ScanMaker 5900 New Locking Mechanism Replacement, Continue latch detachment: step 4, image 1 of 3 Microtek ScanMaker 5900 New Locking Mechanism Replacement, Continue latch detachment: step 4, image 2 of 3 Microtek ScanMaker 5900 New Locking Mechanism Replacement, Continue latch detachment: step 4, image 3 of 3
    • After placing one plastic opening tool into the slit, slide other plastic opening tools along the slit to detach the top from the bottom of the chassis.
    • Go all the way along the chassis until you can lift the upper lid.
  5. Microtek ScanMaker 5900 New Locking Mechanism Replacement, Fully remove the upper lid: step 5, image 1 of 3 Microtek ScanMaker 5900 New Locking Mechanism Replacement, Fully remove the upper lid: step 5, image 2 of 3 Microtek ScanMaker 5900 New Locking Mechanism Replacement, Fully remove the upper lid: step 5, image 3 of 3
    • Do not fully remove the lid until you remove the ribbon cable attached to the front of the upper lid.
    • Do this by grabbing the upper lid from the sides and rotating it ninety degrees so it is perpendicular to the bottom lid.
    • Grab the ribbon cable and gently pull it out of its slot with your fingers.
    • The upper lid can now safely be removed from the bottom lid.
  6. Microtek ScanMaker 5900 New Locking Mechanism Replacement, Remove locking mechanism: step 6, image 1 of 3 Microtek ScanMaker 5900 New Locking Mechanism Replacement, Remove locking mechanism: step 6, image 2 of 3 Microtek ScanMaker 5900 New Locking Mechanism Replacement, Remove locking mechanism: step 6, image 3 of 3
    • Locate the locking mechanism in the front left hand corner of the device.
    • Gently push on it until it becomes loose.
    • Rotate and jiggle it until it comes out the bottom of the scanner.
    • Find a replacement locking mechanism and insert it into the scanner.
Taylor Nesheim
59 Reputation
7 Guides authored
Cal Poly, Team 6-9, Regan Fall 2011 Member of Cal Poly, Team 6-9, Regan Fall 2011
CPSU-REGAN-F11S6G9
2 Members
22 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 10
All Time: 1,334
