Introduction
This guide shows the owner of the scanner how to replace the two bulbs located in the upper lid of the scanner.
Loosen the screws on the serial port by turning them counter clockwise by hand.
After loosening the screws, pull the serial port out.
Lift lid to its vertical position.
Pull lid straight up to remove it from the scanner.
Grab the plastic wire housing near the serial port.
Gently pull and jiggle the wire housing until it comes free from the circuit board.
Gently lift up the bulbs and remove the wires from the plastic.
After completely freeing the bulbs, buy new ones and replace.
