Mid F900 Motherboard Replacement
  1. Mid F900 Motherboard Replacement, Back Cover: step 1, image 1 of 1
    • Using a J00 Phillips-head screwdriver, remove the two screws located at the bottom of the device.
    • Screws are 5mm x 1mm in size.
  2. Mid F900 Motherboard Replacement: step 2, image 1 of 2 Mid F900 Motherboard Replacement: step 2, image 2 of 2
    • Use the plastic opening tool to pry off the white back-plate of the device.
  3. Mid F900 Motherboard Replacement, Motherboard: step 3, image 1 of 2 Mid F900 Motherboard Replacement, Motherboard: step 3, image 2 of 2
    • Using a +00 Phillips head screwdriver, remove the screws securing the motherboard to the device housing.
    • Screws are 4mm x 1mm in size.
  4. Mid F900 Motherboard Replacement: step 4, image 1 of 2 Mid F900 Motherboard Replacement: step 4, image 2 of 2
    • Desolder the two black and red wires connected to the motherboard.
    • Unclip and remove the ribbon cables attached to the motherboard.
    • For soldering help, use the How to Solder and Desolder Connections guide.
  5. Mid F900 Motherboard Replacement: step 5, image 1 of 2 Mid F900 Motherboard Replacement: step 5, image 2 of 2
    • Carefully lift and remove the motherboard from the device housing.
Matthew Oliva
364 Reputation
3 Guides authored
USF Tampa, Team 6-6, Remmell Fall 2016 Member of USF Tampa, Team 6-6, Remmell Fall 2016
USFT-REMMELL-F16S6G6
3 Members
10 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 5
All Time: 325
