Midea MRU03M2ABB Upright Freezer Door Replacement
  1. Midea MRU03M2ABB Upright Freezer Door Replacement, Door: step 1, image 1 of 2 Midea MRU03M2ABB Upright Freezer Door Replacement, Door: step 1, image 2 of 2
    • Unplug the device.
    • Only unplug when your hand is dry.
  2. Midea MRU03M2ABB Upright Freezer Door Replacement: step 2, image 1 of 1
    • Empty the shelves.
  3. Midea MRU03M2ABB Upright Freezer Door Replacement: step 3, image 1 of 3 Midea MRU03M2ABB Upright Freezer Door Replacement: step 3, image 2 of 3 Midea MRU03M2ABB Upright Freezer Door Replacement: step 3, image 3 of 3
    • Use a plastic spatula to remove the hinge cover on top of the freezer.
    • Pushing at the pointy part of the cover makes it easier to remove.
  4. Midea MRU03M2ABB Upright Freezer Door Replacement: step 4, image 1 of 3 Midea MRU03M2ABB Upright Freezer Door Replacement: step 4, image 2 of 3 Midea MRU03M2ABB Upright Freezer Door Replacement: step 4, image 3 of 3
    • Unscrew the hinge counterclockwise.
  5. Midea MRU03M2ABB Upright Freezer Door Replacement: step 5, image 1 of 2 Midea MRU03M2ABB Upright Freezer Door Replacement: step 5, image 2 of 2
    • Lift the hinge out of the freezer and the door.
  6. Midea MRU03M2ABB Upright Freezer Door Replacement: step 6, image 1 of 3 Midea MRU03M2ABB Upright Freezer Door Replacement: step 6, image 2 of 3 Midea MRU03M2ABB Upright Freezer Door Replacement: step 6, image 3 of 3
    • With two hands, gently hold and open the door as usual.
    • Lift the door up to remove it from the bottom hinge.
    • You have completely detached the door from the freezer.
  7. Midea MRU03M2ABB Upright Freezer Door Replacement: step 7, image 1 of 3 Midea MRU03M2ABB Upright Freezer Door Replacement: step 7, image 2 of 3 Midea MRU03M2ABB Upright Freezer Door Replacement: step 7, image 3 of 3
    • With the new door, locate the hole underneath the door.
    • Using two hands, gently place the door on top of the hinge (the pointy part of the hinge should fit inside the hole).
    • Close the door.
  8. Midea MRU03M2ABB Upright Freezer Door Replacement: step 8, image 1 of 3 Midea MRU03M2ABB Upright Freezer Door Replacement: step 8, image 2 of 3 Midea MRU03M2ABB Upright Freezer Door Replacement: step 8, image 3 of 3
    • Use your hand to align the door so these three screw holes stay on the same line.
    • Carefully place the top hinge to fit these holes.
  9. Midea MRU03M2ABB Upright Freezer Door Replacement: step 9, image 1 of 2 Midea MRU03M2ABB Upright Freezer Door Replacement: step 9, image 2 of 2
    • Thread and tighten the screws clockwise.
    • Gently swing the door to make sure it operates well.
  10. Midea MRU03M2ABB Upright Freezer Door Replacement: step 11, image 1 of 2 Midea MRU03M2ABB Upright Freezer Door Replacement: step 11, image 2 of 2
    • Finally, firmly press the cover onto the hinge to secure it. Now, you have completely replaced the door.
    • A "click" will indicate that the cover is finally in its place.
Finish Line
Thinh Lang
193 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 6
Past 7 Days: 9
Past 30 Days: 38
All Time: 148
