Introduction
Hello! In this repair guide you will learn how to replace a Midland WR-120 EZ antenna. Let's get started!
Locate the antenna mount and remove the screw using a Phillips #1 screwdriver. After, pull the old antenna out.
Unless you want to keep the old screw and copper washers for spares, don't worry about them. New ones come with the replacement antenna.
Use something like a pick to arrange the copper washers so that the screw can pass through.
Put the screw in through the indented side of the mount and screw it in.
If you receive a weather forecast from your radio, then you have properly installed a new antenna!
And with that, your WR-120's antenna should be working properly!
