Midland X-tra Talk Radio LXT118 Front buttons Replacement
  1. Midland X-tra Talk Radio LXT118 Front buttons Replacement, Batteries: step 1, image 1 of 2 Midland X-tra Talk Radio LXT118 Front buttons Replacement, Batteries: step 1, image 2 of 2
    • First, apply pressure with your thumb on the top of the battery cover.
    • Next, pull down on the cover until it begins to slide.
  2. Midland X-tra Talk Radio LXT118 Front buttons Replacement: step 2, image 1 of 1
    • Finally, once the cover is completely off, pry up the old batteries with your finger or a strong, skinny tool (i.e. spudger).
  3. Midland X-tra Talk Radio LXT118 Front buttons Replacement, Case: step 3, image 1 of 1
    • Unscrew the six 8.0 millimeter long, #0 screws on the backside of the case using the Phillips #0 screwdriver.
  4. Midland X-tra Talk Radio LXT118 Front buttons Replacement: step 4, image 1 of 1
    • Detach back part of the case by gently lifting up.
  5. Midland X-tra Talk Radio LXT118 Front buttons Replacement, Front buttons: step 5, image 1 of 1
    • Once the back case is already off, use your fingers to lift up the circuit board from the side opposite the antenna.
  6. Midland X-tra Talk Radio LXT118 Front buttons Replacement: step 6, image 1 of 1
    • Lay the circuit board down on the side, as you will not want it interfering with your work on the buttons!
  7. Midland X-tra Talk Radio LXT118 Front buttons Replacement: step 7, image 1 of 1
    • Grasp the rubber cast around the buttons from one side, and slowly lift upwards. Make note of which way the buttons fit into the plastic casing!
    • At this point, the buttons can be cleaned in accordance with the radio buttons are stuck or sticking troubleshooting guide.
    • The speaker does not need to removed in order to get to the buttons.
2 other people completed this guide.
Logan
282 Reputation
2 Guides authored
Cal Poly, Team 19-43, Regan Winter 2013 Member of Cal Poly, Team 19-43, Regan Winter 2013
CPSU-REGAN-W13S19G43
3 Members
9 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 13
All Time: 1,060
