milk frother Aerolatte
  1. milk frother Aerolatte, Remove bottom plate: step 1, image 1 of 2 milk frother Aerolatte, Remove bottom plate: step 1, image 2 of 2
    • Remove the three screws with a screwdriver PH2
    • There is a little triangle impressed in the bottom plate to show the position of the on-switch.
  2. milk frother Aerolatte: step 2, image 1 of 2 milk frother Aerolatte: step 2, image 2 of 2
    • Pull the bottom plate as far away from the housing as possible.
    • A red and a blue cable connect the motor and a plug. Pull out the plug from the circuit board.
    • On one side of the plug you see two slots. You can see the cable shoes in there.
    • With something pointed (eg. watchmaker's screwdriver) you press in one slot to open the cable shoe's locking catch. At the same time you pull on the cable.
    • Do the same with the second cable.
    • Exchange the position of the cables and push the cable shoes back in the plug.
    • The milk frother is re-assambled in reverse order.
    • Plug in the device, fill in some liquid an press the "cold foam" button. Now the motor should turn again. At the first time it might be necessary to give a little push by hand. The motor speed increases fast and remains.
Finish Line
Special thanks to these translators:
de en
100%
John Maier is helping us fix the world! Want to contribute?
Start translating ›
John Maier
1,360 Reputation
3 Guides authored
One Comment
Bei unserem bauähnlichen Milchschäumer Petra ließ sich das gleiche Problem genauso beheben.
John Maier - Reply
Past 24 Hours: 0
Past 7 Days: 11
Past 30 Days: 38
All Time: 4,486
