Milwaukee 5262-21 Motor Housing Replacement
  1. Milwaukee 5262-21 Motor Housing Replacement, Housing Assembly: step 1, image 1 of 1
    • Remove the ten 19mm T20 Torx screws shown in red.
  2. Milwaukee 5262-21 Motor Housing Replacement: step 2, image 1 of 1
    • Remove the red Housing Assembly by lifting it up off of the tool.
  3. Milwaukee 5262-21 Motor Housing Replacement, Fan Baffle: step 3, image 1 of 2 Milwaukee 5262-21 Motor Housing Replacement, Fan Baffle: step 3, image 2 of 2
    • Now the two 10mm T-10 screws shown in red can be removed.
    • Next, remove the two 10mm T-10 screws located on the other side of the tool shown in orange.
  4. Milwaukee 5262-21 Motor Housing Replacement: step 4, image 1 of 2 Milwaukee 5262-21 Motor Housing Replacement: step 4, image 2 of 2
    • Using the metal spudger, remove each brush holder as shown in the images.
  5. Milwaukee 5262-21 Motor Housing Replacement: step 5, image 1 of 3 Milwaukee 5262-21 Motor Housing Replacement: step 5, image 2 of 3 Milwaukee 5262-21 Motor Housing Replacement: step 5, image 3 of 3
    • Remove the four 37mm T-20 screws shown in red. These screws attach the gear housing to the motor housing.
  6. Milwaukee 5262-21 Motor Housing Replacement: step 6, image 1 of 2 Milwaukee 5262-21 Motor Housing Replacement: step 6, image 2 of 2
    • After removing the four screws, pull apart the the two sections.
  7. Milwaukee 5262-21 Motor Housing Replacement: step 7, image 1 of 2 Milwaukee 5262-21 Motor Housing Replacement: step 7, image 2 of 2
    • Remove the four 12mm screws with a T-15 Torx screwdriver shown in red.
    • These screws hold the fan baffle in place.
  8. Milwaukee 5262-21 Motor Housing Replacement: step 8, image 1 of 2 Milwaukee 5262-21 Motor Housing Replacement: step 8, image 2 of 2
    • Remove the fan baffle by pulling it out.
  9. Milwaukee 5262-21 Motor Housing Replacement, Motor Housing: step 9, image 1 of 2 Milwaukee 5262-21 Motor Housing Replacement, Motor Housing: step 9, image 2 of 2
    • Pull the black wire(shown in the image) out of the trigger assembly.
  10. Milwaukee 5262-21 Motor Housing Replacement: step 10, image 1 of 2 Milwaukee 5262-21 Motor Housing Replacement: step 10, image 2 of 2
    • Pull the white wire (shown in the image) out of the trigger assembly.
  11. Milwaukee 5262-21 Motor Housing Replacement: step 11, image 1 of 2 Milwaukee 5262-21 Motor Housing Replacement: step 11, image 2 of 2
    • Using a metal spudger slide the black wire (shown in the image) out of the trigger assembly.
  12. Milwaukee 5262-21 Motor Housing Replacement: step 12, image 1 of 2 Milwaukee 5262-21 Motor Housing Replacement: step 12, image 2 of 2
    • Using a metal spudger slide the yellow wire (shown in the image) out of the trigger assembly.
  13. Milwaukee 5262-21 Motor Housing Replacement: step 13, image 1 of 3 Milwaukee 5262-21 Motor Housing Replacement: step 13, image 2 of 3 Milwaukee 5262-21 Motor Housing Replacement: step 13, image 3 of 3
    • After disconnecting the wires, push the 120v Field Assembly out of the motor housing.
    • You may need to use a screwdriver to push the assembly from behind.
  14. Milwaukee 5262-21 Motor Housing Replacement: step 14, image 1 of 3 Milwaukee 5262-21 Motor Housing Replacement: step 14, image 2 of 3 Milwaukee 5262-21 Motor Housing Replacement: step 14, image 3 of 3
    • Once the assembly is loose, pull each half out of the housing.
    • Note the orientation of how the halves sit together in the housing before removal.
  15. Milwaukee 5262-21 Motor Housing Replacement: step 15, image 1 of 2 Milwaukee 5262-21 Motor Housing Replacement: step 15, image 2 of 2
    • Remove the motor housing from the device.
Andrew Floyd
277 Reputation
2 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 8
All Time: 294
